Thread: Fun TPS Issues
Results 1 to 2 of 2
  1. #1 Fun TPS Issues
    Sep 2014
    South Carolina
    My car has had an issue for some time that has finally gotten on my nerves enough for me to make a post about it searching for a solution.
    I have a N* TB and have tried at least three different TPS and at least two different brands of TPS.
    The issue is that the TPS will erratically show non zero values despite there being absolutely no throttle input. It will sometimes only show up to 1% and then go back to zero and other times I've seen it go up to 8% and then back to zero. It will almost never sit at zero.
    As you can guess this causes some erratic idle speeds too. I'm not sure what else to troubleshoot since I've tried the TPS itself.
    Sent from my LGUS997 using Tapatalk
    Gen V M90 | 3.2" Pulley | N* Throttle Body | ZZP SSIC | S1X Blower Cam | INTENSE SIII Heads | 42# Injectors | Pacesetter Headers | Aluminum Subframe | ZZP Lowering Springs | KYB AGX Struts
  2. #2 Re: Fun TPS Issues
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Erratic idle? Look for a vac leak. Could be as simple as the vacuum harness or one of the T's. How's your maf? Clean or screen ripped out for extra "performance"?
    The same thing happening several times, I'd start looking at a different area.
  1. Gtp issues
    By 98RedunicornGtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2015, 07:49 PM
  2. Key Fob Issues
    By i3abydoll in forum General Grand Prix Discussion
    Last Post: 05-07-2015, 11:14 PM
  3. HID issues
    By 1996pontiac in forum Visual/Body Modifications
    Last Post: 12-19-2012, 11:09 AM
  4. TCS/ABS issues?
    By Iced Iridium in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2012, 06:51 PM
  5. 99 gtp issues
    By Dan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2009, 10:29 PM
