Thread: Gtp issues
Results 1 to 9 of 9
  1. #1 Gtp issues
    Nov 2015
    Elizabethtown
    I have 98 Gtp having misfire in cylinder 3 and 4 only at idle . On the highway I could be doing 75 and try and give it gas slowly and it sounds like it's bogging down till supercharger makes boost . My abs light and tsc off light stays on and recent had swap back to stock pcm after a ecu malfunction code which made my car shift really hard and delayed . Changed plugs and coil paks wires check injectors . And tryed to swap things around to chase the misfire but no movement. My interceptor gauge reads 14 misses in 4 in the cycle scan and 2 in cylinder 3 . I checked plugs the had orange tips normalburn idk . I know I need new pcm but unsure of my setup . 3.5 pulley cold air intake stock injectors and slp exhaust . Any tips ?
  2. #2 Re: Gtp issues
    Feb 2013
    37.295091, -121.930053
    try swaping the coil packs around and see if it moves if it doesnt you chipped a pistion by using low octaine for to long
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Gtp issues
    He didn't say thing about octane though, so you don't have proof of that.
    More so would the pulley drop without enough exhaust mods could chip a piston.
    What kind of plugs are you running and what gap?
  4. #4 Re: Gtp issues
    Nov 2015
    Elizabethtown
    Stock acdelco uraduim100 thousand mile ones and I use 92-93 gas everytime stock header down to the u bend then it's slp out tryed changing coils with used working ones and moving them around even wires And third gear Boggs like hell got to push pedal to get it outta the bogging .
  5. #5 Re: Gtp issues
    Nov 2015
    Elizabethtown
    Plugs came pre gapped on count of the tiny electrode.
  6. #6 Re: Gtp issues
    So .060" on iridium plugs with a 3.5 and no other real flow mods.
    Which plug fouling would you say it looks like?
    Gtp issues Attached Images
  7. #7 Re: Gtp issues
    Nov 2015
    Elizabethtown
    All the plugs looked fine but he was running autolites cylinder 4 is the worst and cylinder 2 and 3 sometimes when cruising but at idle it number four and three will pop up once in while.
  8. #8 Re: Gtp issues
    Nov 2015
    Elizabethtown
    Prong was orange with clean burn rest was black chard I was told it was a normal looking plug wasn't shinny or burnt or wet
  9. #9 Re: Gtp issues
    Nov 2015
    Elizabethtown
    The second one by the tiny image
  1. 2 issues
    By 2001gp in forum General Tech Discussion
    Last Post: 06-24-2014, 06:36 PM
  2. kr issues
    By jrb1027 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2013, 08:03 PM
  3. TCS/ABS issues?
    By Iced Iridium in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2012, 06:51 PM
  4. ABS Issues
    By jmoore4294 in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2012, 01:58 PM
  5. A/C Issues
    By ReaperRob in forum General Tech Discussion
    Last Post: 08-10-2009, 09:55 PM
