Thread: Misfires, raw fuel smell, codes p0128 p0300
Results 1 to 5 of 5
  1. #1 Misfires, raw fuel smell, codes p0128 p0300
    Ohio
    Looking for some ideas on this one. Had to have the regal towed back home this morning. With no warning, started running rough and was way down on power. Getting HEAVY fuel smell out exhaust, and these codes:
    p0128 coolant thermostat
    p0300 Random/multiple misfire
    p0420 Catalyst below efficiency, bank 1
    I believe the 0420 has been there since I installed the ZZP DP several years ago. The raw fuel smell is very strong, like straight fuel out the tailpipe. Any ideas where to check first? I'd appreciate any help.
  2. #2 Re: Misfires, raw fuel smell, codes p0128 p0300
    Jun 2018
    Lehigh Valley
    First things I would check are plugs, wires, coil packs and ignition control module. When was the last time you had a tune up?
    '97 Grand Prix GT Coupe
    '05 Grand Prix GTP Sport Red Metalic SOLD
    '05 Grand Prix GTP Silver
  3. #3 Re: Misfires, raw fuel smell, codes p0128 p0300
    HUDSON
    If you smell raw fuel, better check all your fuel line fittings for leaks, especially where the fuel lines connect to the fuel rail.
  4. #4 Re: Misfires, raw fuel smell, codes p0128 p0300
    Kemmerer, Wyoming
    your catalytic converter could be plugged causing the computer to dump fuel in it to try and clean it out. on a separate issue, your thermostat could be stuck open causing the engine to run rich. I would put a new thermostat in and see if that fixes one of your problems.
  5. #5 Re: Misfires, raw fuel smell, codes p0128 p0300
    Ohio
    Thanks guys. I will start with the t-stat and go from there. I'll have to dig out my receipts and see when things were last replaced. There def is not a fuel leak though- it's unburnt fuel dumping out the exhaust. It will be a couple days, but I will post back with findings.
  1. P0300 and p1381 codes?
    By suitercrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2017, 07:42 PM
  2. Replies: 12
    Last Post: 06-27-2016, 07:14 AM
  3. P0300 and P0305 Codes
    By sholdwick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2014, 10:51 AM
  4. p0300 random misfires
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2013, 09:44 PM
  5. GT engine trouble codes p0300 and p0108
    By Coyote86 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2013, 02:12 PM
