Thread: P0300 and p1381 codes?
Results 1 to 6 of 6
  1. #1 P0300 and p1381 codes?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    I was driving home today and these codes popped up. I set my aeroforce to scan misfires and sure enough when under throttle I was having misfires in what looked like all the cylinders, the kicker though is that the car runs perfect and has absolutely no loss in power from what I can tell. I'm not even seeing any knock or anything. I did just do a case relearn using the aeroforce yesterday and noticed the procedure was different then any other case learn I've done using a tech 2 or dhp
    Sent from my LG-H901 using Tapatalk
  2. #2 Re: P0300 and p1381 codes?
    SE Level Member Monday's Avatar
    May 2012
    Danielleland
    Clearly you are seeing some misfires. So I'd go after that.
    Meanwhile
    http://www.gmforum.com/obd-ii-troubl.../p1381-284173/
  3. #3 Re: P0300 and p1381 codes?
    Oct 2015
    Ya I'm just not sure if the misfires im seeing are real. You would think if it was bad enough to throw a cel it would be noticeable.
  4. #4 Re: P0300 and p1381 codes?
    Mar 2017
    Internet
    Don't be so sure. I once swapped my Regals trans and found the issue to be worse and consistent. Ended up being a bad coil. Life is good when you have a spare trans lying around and you don't mind swapping. Literally got to the point of shotgunning parts because it had to be electrical and I couldn't see it on a scanner or feel it driving.
  5. #5 Re: P0300 and p1381 codes?
    Oct 2015
    Well I have a spare icm, and coil packs. So that's a good start I guess
  6. #6 Re: P0300 and p1381 codes?
    Mar 2017
    Internet
    worth a try
  1. 2002 SE codes C0245, P0171, and P0300.
    By XeroTheory in forum General Tech Discussion
    Last Post: 10-01-2014, 09:09 AM
  2. P0300 and P0305 Codes
    By sholdwick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2014, 10:51 AM
  3. GT engine trouble codes p0300 and p0108
    By Coyote86 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2013, 02:12 PM
  4. CEL problem codes, P0102, P0300, P1381 and a few more UPDATED!
    By buickman104 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2012, 11:01 AM
  5. Bad idle and RPM issues not to forget codes P0303, P0341, AND P0300
    By jessiinicole in forum Off Topic Discussion
    Last Post: 03-08-2010, 02:27 PM
