Thread: Engine Swap
Results 1 to 11 of 11
  1. #1 Engine Swap
    MINNESOTA
    I have a question , my friend and I want to swap engines from a 2009 g8 v6 and put it in a 2009 g6 GXP v6
    Is it possible, any parts that need to be taken off or not
    The engine on the GXP died on him and we found on from a G8
    It has been a while since I posted here, but glad to be back
    Thank you
  2. #2 Re: Engine Swap
    I believe you are suggesting a RWD to FWD swap. That could be a ton of fab work
  3. #3 Re: Engine Swap
    I'd be concerned with bell housing bolts because the G8 is hooked up to a RWD transmission and not the FWD that the G6 has.
    The rest is how different are the blocks for motor mounts, belt routing, pulley and alternator placement and brackets.
  4. #4 Re: Engine Swap
    St. Louis
    Pretty sure that motor is specific to the GXP G6. Maybe check car-part.com or LKQ and see if you can source a good replacement.
  5. #5 Re: Engine Swap
    MINNESOTA
    Dang, he bought the engine cause the guy told him that it would fit with no problems
    Maybe he can call the guy back and have him take it back
  6. #6 Re: Engine Swap
    MINNESOTA
    Hope is not a lot of work getting it to work
  7. #7 Re: Engine Swap
    MINNESOTA
    Well I guess he is stuck with the engine
    We would appreciate a little help
    I am going to try and find some pics of both engines and see what the difference is
    The guy didn't have enough money for a used engine from the junk yard so he figure he could save couple hundred dollars
  8. #8 Re: Engine Swap
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    Quote Originally Posted by valente View Post
    Don't kidd yourself man. This is going to be a huge undertaking. Sounds like a challenge even for the most experienced gear head. Will the engine even fit in the engine bay? G6's have a small, narrow chasiss especially up font.
    No one on this site knows a thing about G6's. There is a G8 section, but its pretty thin. You're gonna need help from the G8/G6 forums more than from the 3800/W-Body guys.
    Good Luck!
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  9. #9 Re: Engine Swap
    MINNESOTA
    Quote Originally Posted by CHI2000GTP View Post
    Good Luck!
    thank you
    Going to keep searching
    Hopefully we can get his car going again
  10. #10 Re: Engine Swap
    A tow truck can get it going at least 70mph from my experience!
    Sorry.. had to
  11. #11 Re: Engine Swap
    MINNESOTA
    Sorry.. had to
    LOL
  1. Engine swap / Trans swap 2001 gtp v. compatible years
    By Banana Hammock in forum General Grand Prix Discussion
    Last Post: 07-06-2016, 08:27 AM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  4. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
