Thread: P0341 FaultybCam or Crank sensor questions?
Results 1 to 8 of 8
  1. #1 P0341 FaultybCam or Crank sensor questions?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok today after driving for about an hour in 115°+ weather my car randomly studdered for a few seconds, then died completely and would crank but, not fire. I let it cool down and then drove it fine for about 10 minutes before stalling again and me having to wait for it to cool off. I immediately thought it was the crankshaft sensor since these cars are notorious for that going out and no start condition. Looking at the aeroforce it showed the p0341 cel code which is a camshaft sensor range problem. So my question is..
    Does a faulty camshaft sensor cause the same no start the crank sensor does?
    Also is there a chance its not actually the cam sensor and its the crank sensor?
    I havent heard or read anyone that had a cam sensor go bad, but ive seen 100 bad crankshaft sensor threads. Their all wired together and work off eachother so i figured maybe its actually the crank.
    Lastly what brand is the best, i normally just get ac delco, unless someone had a better one or problems with it. Thanks guys!!
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: P0341 FaultybCam or Crank sensor questions?
    Camshaft sensor issue will give you a 1 in 6 chance of starting. Check the connector/wiring going to it. Cam sensor failures are not overly common. I would pull the sensor and stick a finger into the sensor hole and feel around for the magnet. Turn the engine a little and checking for the magnet. If someone the magnet is missing from the cam gear, it can cause the code and for you to pull the timing cover. That was common on the Series I 3800 (never in GP), and not common in the S2/S3, but I'd check anyhow.
  3. #3 Re: P0341 FaultybCam or Crank sensor questions?
    Jul 2010
    Coquitlam,BC,Canada
    I replaced my crank sensor 5 years ago, but turned out to be a wiring issue. I used a Delco sensor and it has worked just fine.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: P0341 FaultybCam or Crank sensor questions?
    Confused Chris.. he said he had a cam sensor code, not a crank code. One doesn't toss a code for the other.
  5. #5 Re: P0341 FaultybCam or Crank sensor questions?
    Jul 2010
    Coquitlam,BC,Canada
    They were talking cam and crank, and brand, thus my reply. Just trying to help.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: P0341 FaultybCam or Crank sensor questions?
    I get it now.. nice!
  7. #7 Re: P0341 FaultybCam or Crank sensor questions?
    Oct 2015
    Thanks for the input guys, ive been really busy and finally ready to fix this problem. I cant stand driving the 200hp 2014 Sonata its like a ginormous gocart at full throttle, sounds way to similar as well..
    Is there any specific wires I should check on the ignition harness, or if someone can link me a diagram for it. I know ive seen one around, but for the life of me cant find it now that I actually need it.
    Sent from my LG-H830 using Tapatalk
  8. #8 Re: P0341 FaultybCam or Crank sensor questions?
    stand on passenger side of car.. stick your left hand down into engine bay and stick a finger at 7-8 oclock on the water pump pulley. Feel that sensor.. that's your cam sensor. Now if wires got buggered.. it's likely over by the crank or just over the crank. You can pick up a harness off nearly any 3800. It goes from the icm to a connector right behind the icm, down to crank and over to cam sensor.
  1. Bad Crank Sensor? PCM?
    By Moozery in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2017, 06:54 PM
  2. P0340, P0341 camshaft sensor
    By johndaysGT in forum 5.3L V8 (LS4)
    Last Post: 12-21-2013, 07:28 PM
  3. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. 3.1 crank sensor wire
    By 68galaxie500 in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-22-2010, 09:18 PM
