Thread: Any Good Threads on Replacing Hub Bearings? '07 Grand Prix
Results 1 to 5 of 5
  1. #1 Re: Any Good Threads on Replacing Hub Bearings? '07 Grand Prix
    pop the tie rod end out, will let the knuckle move more freely for ya.
    God no.. worst idea ever.
    Grab a shallow 1/2" socket and a wobble extension. Now pull out a ratchet with some length and your muscle. You'll have it in no time. I've written so many how to's with the basis that it's the easiest way possible. Pulling the tie rod will not give you any addition access because the cv is in the hub either way. all it's going to do is give a guy w/o airtool the hardest battle of their life.
  2. #2 Re: Any Good Threads on Replacing Hub Bearings? '07 Grand Prix
    Jul 2010
    Coquitlam,BC,Canada
    I turn the wheel to full lock, remove 1 or 2 of the bolts, then turn the other way to full lock and remove the rest. By doing it this way, you don't need any wobble extensions, just a straight 6-8" one. I found even with wobble's and an impact it was a biatch.
    And if you can't remove the axle nut, use the spare tire as seen in the first part of my write-up.....
    Wheel_Bearing
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Replies: 3
    Last Post: 07-24-2012, 08:41 AM
  2. Replacing Needle Bearings
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 05-07-2012, 08:28 AM
  3. Replacing snout bearings
    By vsl67 in forum How To Write-Ups/Tech Tips
    Last Post: 12-29-2010, 07:20 PM
  4. 99 grand prix rear bearings
    By kevinc2187 in forum Brakes/Suspension/Chassis
    Last Post: 06-19-2009, 10:34 AM
  5. Replacing bearings for SC case
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2009, 02:31 PM
