Thread: Auxiliary power not working
Results 1 to 6 of 6
  1. #1 Auxiliary power not working
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Hi All,
    My 07 GTs auxiliary sockets are not getting power. I have checked the fuses several times over and they are all good. one of them used to work but now they are both dead so I am assuming a possible wiring issue. Has anyone ever had this issue or have heard of a fix or starting point? Thanks for any suggestions
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Auxiliary power not working
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Well, for starters, is there anything else not working? If not, I'd start by checking for voltage immediately behind the socket. They can go bad. If that doesn't work, let me know and I'll dig up some diagrams to tell where to test next.
  3. Likes rickisrad liked this post
  4. #3 Re: Auxiliary power not working
    check both fuse boxes?
  5. Likes rickisrad liked this post
  6. #4 Re: Auxiliary power not working
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Thanks for the replies,
    Everything else is working fine. I will pull the center console to check voltage at the base.
    I did check both fuse boxes and everything is okay there
  7. #5 Re: Auxiliary power not working
    Aug 2017
    Raytown, MO
    Oh, and don't forget to do a power drop test for good ground, they share a common ground. And test for power with current ground wire, and with a known good ground. Easiest to do with test probe. Harbor freight sells good ones for cheap, you can use a multimeter too.
  8. #6 Re: Auxiliary power not working
    Aug 2017
    Raytown, MO
    Check aux fuse 10 in your owner's manual under the hood first.
  1. Power Locks Working intermittently
    By sn95gt50 in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2016, 01:19 PM
  2. Auxiliary power drop. Guage hook up. Where is it?
    By FIRECHICKEN in forum Audio, Security & Visual Electronics
    Last Post: 11-29-2014, 05:38 PM
  3. Power steering only working to the right
    By dsmuts in forum Brakes/Suspension/Chassis
    Last Post: 04-13-2011, 05:46 PM
  4. auxiliary power drop
    By macey43 in forum Audio, Security & Visual Electronics
    Last Post: 08-01-2010, 09:47 PM
  5. Power Door Locks not working
    By webracin in forum General Tech Discussion
    Last Post: 12-27-2007, 10:57 AM
