Thread: Power Locks Working intermittently
Results 1 to 9 of 9
  1. #1 Power Locks Working intermittently
    SE Level Member sn95gt50's Avatar
    Jul 2008
    2008 Grand Prix
    Power door locks started not working intermittently sometimes one will work sometimes all sometimes none.
    Trying to diagnose, when you hit lock or unlock (remote or door switch) when they don't work, you will see them move just a little like they want to come up but they won't. We have also noticed a correlation between heat, if it is hot outside they are much less likely to work and when it is cooler (night) they are more likely to work.
    This leads me to believe it is probably the actuators getting weak, but, want to be sure before throwing parts at it. I assume that the actuators get either no volts or 12 volts, is this correct. If so, I should be able to test to see if they are getting the full 12 volts at any time.
    Any advice would be appreciated.
    Thanks,
    John
  2. #2 Re: Power Locks Working intermittently
    Omaha, NE
    I had that happen once and resolved the issue by replacing the switches.
  3. #3 Re: Power Locks Working intermittently
    Jul 2008
    Are you talking about the door lock switch on the driver door?
  4. #4 Re: Power Locks Working intermittently
    Jul 2008
    When you had the problem would the locks work from the remote?
  5. #5 Re: Power Locks Working intermittently
    Jul 2008
    We took the door apart and remove the latching mechanism, and tried the lock unlock from the driver panel and the remote. It moves it a little but not enough to lock or unlock.
    I may just replace the switch like explicit suggested and see if that helps. I am guessing the chevy dealer will just give me one out of the kindness of their hearts (sarcasm).
    Does the remote and auto door lock/unlock work via the switch as well?
    Any help as always is appreciated.
    Thanks,
    John
  6. #6 Re: Power Locks Working intermittently
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Junk yard spelunking time, just about any 04+ should have the same door switches.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  7. #7 Re: Power Locks Working intermittently
    GXP Level Member
    Mar 2015
    Tomball
    I've had the same issue for a while. I haven't done anything other than manually lock any of the doors that don't actually lock. I need a new switch panel anyway because the lettering is gone.
  8. #8 Re: Power Locks Working intermittently
    Jul 2008
    Is the switch high probability of being the problem? Dealer wants $39 for the switch.
    Do I need to remove the door panel to replace the switch? Any tricks for replacement?
    Thanks,
    John
  9. #9 Re: Power Locks Working intermittently
    GXP Level Member
    Mar 2015
    Tomball
    I wouldn't see why it would make any difference to be honest. It is only an input panel to the BCM, the BCM has the actual relays in it so that would be where the issue would be.
  1. 05 gtp comp g power door locks/remote stopped working
    By Murf88 in forum Introductions/Noob Questions
    Last Post: 07-28-2015, 09:05 PM
  2. AC working intermittently
    By nos4blood70 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2014, 05:43 AM
  3. no crank, no power, key locks, shifter locks
    By flames1819 in forum PCM Tuning
    Last Post: 01-07-2012, 06:06 PM
  4. power windows, locks, moonroof, interior lights not working!! HELP!
    By rottenhippo in forum General Tech Discussion
    Last Post: 10-30-2010, 02:19 PM
  5. Power Door Locks not working
    By webracin in forum General Tech Discussion
    Last Post: 12-27-2007, 10:57 AM
