Thread: Aftermarket fuel pump has different electrical connector, need to find stock one
Results 1 to 3 of 3
  1. #1 Aftermarket fuel pump has different electrical connector, need to find stock one
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    Was there ever a known issue with the stock 4 wire square electrical connector that goes to the fuel pump? I recently bought a '03 GTP with 187,000 miles, and I went to replace the fuel pump with a working pump from a '01 GTP. When I pulled the pump from the '03 and saw the aftermarket pump, I was stopped in my tracks. The owner had an awful Airtex brand pump installed, no wonder he had problems. Even the fuel sender is a different style and can't be replaced with a AC Delco one.
    Anyways, as I was researching fuel pumps for the GP's, one comment made was that a number of Grand Prix and other W-body owners had problems with the AC Delco fuel pump and it was due to the electrical connector design. I was like "uh", never heard of this.
    Now, I got to cut the stock connector off another GP, but can't locate any model years close to the 2003.
    What years used the same fuel pumps?
  2. #2 Re: Aftermarket fuel pump has different electrical connector, need to find stock one
    Oct 2011
    Toledo, OH
    You can use the plug from a O2 sensor also.
    There is a TSB somewhere about the square plug design not making good connection and causing wires to melt. Because of this a lot of pumps, including OEM replacements come with the flat 4 plug on them and an included harness to splice in.
    2005 GTP - Graystone Metallic|SPO grills&spoiler/SE lip/Carbon Fiber INFERNO hood
    7"
    Spectre|3.4 MPS|42lb Blue Giants+E85+Walbro 450lph pump
    SpeedDaddys|AL605|Vogtlands on FE3s|Vinnie's Spacers on solid lowers|Intense poly uppers|
    Dorman + Addco sway bars|Drilled/slotted rotors|Plasti-dip 17" QP2 at +27 offset
  3. #3 Re: Aftermarket fuel pump has different electrical connector, need to find stock one
    Aug 2013
    Pittsburgh, PA
    Thanks for that info about TSB's. I knew they existed, but never really bothered researching them. I found a list of TSB's for the Pontiac Grand Prix, by year. Interesting that I have owned these cars since 1999 and really never bothered looking into these TSB's. I can consult with some local long time GM mechanics about some of the bulletins to see if they can help diagnose certain problems.
    http://www.pontiacproblems.com/tsbs/Grand_Prix/2002/
    Concerning the TSB on the square fuel pump electrical connector and the overheating problem on fuel pumps, I am going to remove the upgraded flat plug and install the 4-pins square plug as I have never had an issue with overheating with any electrical connector or any lack of power to the fuel pump on the Grand Prix's I have owned. Besides, I have a number of pumps from GP's that I know operate fine and I don't want them to go to waste.
  1. Aftermarket fuel pump, good to the last drop?
    By bandook in forum General Tech Discussion
    Last Post: 06-28-2015, 03:15 PM
  2. Fuel pump resistor jumper connector? (Caspers kit)
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 06-07-2014, 08:46 AM
  3. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  4. I can't find my fuel pump resistor to change it...
    By RebelGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2011, 07:48 PM
  5. Fuel pump connector diagram
    By Justinzoso in forum General Tech Discussion
    Last Post: 08-31-2010, 09:42 AM
