Thread: 2008 Grand Prix Door Lock Problem
Results 1 to 16 of 16
  1. #1 2008 Grand Prix Door Lock Problem
    Apr 2011
    California
    I have an issue with the door locks. The FOB will unlock the doors, but not lock them. In addition the switch on the driver’s side door will unlock the doors but not lock them. When the car is put into Drive the doors will not lock (although the setting is set to lock), but when shifted to Park they will unlock (if I manually lock the doors first). Everything else on the FOB works, trunk, panic. This was an intermittent problem but now it is here to stay. I have unplugged the battery, changed the FOB battery and gone through all of the various lock settings, changed them, changed them back… to no avail. Any suggestions on how to fix this?
  2. #2 Re: 2008 Grand Prix Door Lock Problem
    Waukesha, WI
    pull the door panels aparts and check the lock rods to see if there is any binding or bending. and lube while your in there.
    a guy came in with the same problem we ended up putting new latches in all the doors.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: 2008 Grand Prix Door Lock Problem
    Apr 2011
    California
    All four doors? I don't think all four would have that issue happen at the same time...
  4. #4 Re: 2008 Grand Prix Door Lock Problem
    MI
    I don't think its your FOB at all. I'm guessing all of the locking mechanisms that you've tried are tied to the same input (the FOB receiver, the driver side switch and the contact switch in the shifting mechanism) where that inputs goes to be processed sounds like the cause of the problem to me.
  5. #5 Re: 2008 Grand Prix Door Lock Problem
    Apr 2011
    California
    Any idea where the input goes and what I may need to replace. The door lock fuse is good (as the doors will unlock). I don't have a manual so I don't know where the relay is (if there is one). I took the bottom half of the dash off on the drivers side and could not find anything that looked like a relay. The local dealer won't give me any input, they say bring it in and we will take a look (and your money)...
  6. #6 Re: 2008 Grand Prix Door Lock Problem
    Waukesha, WI
    maybe its the drivers switch thats bad?
    RayRay
    92 Turbo miata
    02 lexus is300
  7. #7 Re: 2008 Grand Prix Door Lock Problem
    MI
    I believe all of the inputs feed the BCM (body control module) one way or another. I dont think it would be the driver side switch only either but who knows.
  8. #8 Re: 2008 Grand Prix Door Lock Problem
    SE Level Member GMGUY's Avatar
    Dec 2010
    West Jordan Utah
    Quote Originally Posted by GeeXPee View Post
    I would look at the door switch, its the master cir if its shorting out it may not be completing the cir.. this is where I would start..
  9. #9 Re: 2008 Grand Prix Door Lock Problem
    Indiana
    I have a 2004 Grand Prix but I have been having the exact same problem. I took mine into the dealership today and they said it is a computer module that is causing the problem and it would need to be replaced.
  10. #10 Re: 2008 Grand Prix Door Lock Problem
    Apr 2011
    California
    Did the dealer give you a quote on what it will cost to replace the computer mod? The funny thing is just after I posted the original problem I had a buddy do a scan and there were no issues found. After the scan the locks worked fine for the last week and just yesterday Sybil's (my name for the car) locks were back to the same old problem. I pulled the FOB's apart and the battery clips were broken on both (again... I fixed them last week by re-soldering the connection). Not sure if the FOB's have anything to do with the problem when they are not making good contact with the battery...
  11. #11 Re: 2008 Grand Prix Door Lock Problem
    Northern IL
    I am starting to have the same issue with the 08 I have. Did you track this down to the BCM? I am trying to confirm this before I buy a new one.
  12. #12 Re: 2008 Grand Prix Door Lock Problem
    Nov 2017
    OK
    I am having door lock problem, but in a different manner. The key FOB and the key will lock the door but will not unlock in. The key FOB only unlock the trunk. I need to get this fixed fast as i have left my car unlock for a while now and I am afraid of someone breaking into my car. Thanks
  13. #13 Re: 2008 Grand Prix Door Lock Problem
    Quincy, Mass
    That sounds like the buttons are worn out and the circuit board is dirty. Happened to my wife’s 06, got these pads that go in the fob and haven’t had an issue since, actually forgot all about it until I saw this post
    https://rover.ebay.com/rover/0/0/0?m...2F220646081643
    No more GP 04 Impala SS Indy:
  14. #14 Re: 2008 Grand Prix Door Lock Problem
    Sep 2015
    Cheyenne, WY
    Have you tried using the key old school style?
    Put it in the door lock & turn it!
    That was how we did it back in my day!!!
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  15. #15 Re: 2008 Grand Prix Door Lock Problem
    GTP Level Member
    Oct 2014
    Or just push the drivers door lock button. Once to lock delayed style. Twice to set the alarm.
  16. #16 Re: 2008 Grand Prix Door Lock Problem
    Sep 2015
    Cheyenne, WY
    We even had to open the trunk the same way!
    With a key!
    And to complicate the issue it was a different key!
    But the trunk key was usually rounded so you knew which key started the car/opened the doors & which key opened the trunk.
  1. 2008 Grand Prix...problem?
    By BowTie in forum General Tech Discussion
    Last Post: 01-13-2011, 06:27 PM
  2. 2008 Grand Prix headlight problem
    By buckwheat in forum General Tech Discussion
    Last Post: 09-04-2010, 09:36 AM
  3. 2006 Pontiac Grand Prix Driver door lock doesn't unlock
    By PianoMan99 in forum General Tech Discussion
    Last Post: 09-23-2009, 06:22 AM
  4. Auto Door Lock Problem-2000 GTP
    By sandjaso in forum General Tech Discussion
    Last Post: 08-31-2009, 07:25 PM
  5. Power Door Lock Problem-O
    By flynn in forum General Tech Discussion
    Last Post: 12-31-2007, 04:49 PM
