Thread: 04 GTP questions, seeking mod advice
Results 1 to 20 of 32
  1. #1 Re: 04 GTP questions, seeking mod advice
    Kemmerer, Wyoming
    I know at least one person that runs SD headers and lives in SLC, not sure if he is catless or not, but I would suspect that he does have a catalytic converter, so either he deleted the codes or his catalytic converter works good enough.
  2. #2 Re: 04 GTP questions, seeking mod advice
    SE Level Member derpyimp's Avatar
    Nov 2017
    Utah
    That's good to know. I have 10 months until my emissions are due again, so I guess I'll probably do headers with a high-flow cat and then delete any codes later when I have the means to do some tuning.
  3. #3 Re: 04 GTP questions, seeking mod advice
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by SgtMarshal View Post
    A cheap hi flow cat or a "test pipe" is the way to go if your e testing is an OBD2 check and visual inspection for the cat, a quality hi flow converter is only needed if you need to pass a sniffer test. I had to install a good magna flow HM (high metal content) on my gtp to pass the sniffer before OBD2 check only came in to effect in my area, a universal or cheap hi flow just won't get the job done compared to a stock cat.
  1. Throttle Body Cleaning--Seeking advice
    By Mr D in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2014, 01:17 PM
  2. Seeking advice on rear wheel bearing
    By Exile in forum General Tech Discussion
    Last Post: 12-22-2013, 12:39 AM
  3. Seeking leagal advice in an accident/hit&run
    By Prixer97 in forum General Grand Prix Discussion
    Last Post: 05-01-2013, 10:29 PM
  4. New Car and Preservation Concerns (seeking advice)
    By younger5th in forum General Grand Prix Discussion
    Last Post: 04-03-2013, 07:02 PM
  5. Seeking Advice about Lowering Springs/Rims
    By mRa in forum Visual/Body Modifications
    Last Post: 04-10-2010, 11:55 PM
