Thread: Having a problem with lights
Results 1 to 6 of 6
  1. #1 Having a problem with lights
    Nov 2017
    WV
    Hi.. I am new to the forum so I am not sure where to post this. If this isn't the right place please let me know.
    My turn signals seem to only want to work when they feel like it. When i turn one on it won't light up or blink at all AND my brake lights won't work on that side. When i turn the blinker off the brake lights work again. This is on both sides of the car and both the front and the rear.
    Any suggestions? I can't afford to take it to a garage so any suggestions where to start would be good.
    Thank you
  2. #2 Re: Having a problem with lights
    id start with checking all the bulbs. the rears tend to get wet and corrode the sockets, causing all sorts of odd things.
    if they are clean the multi switch would be next, the part with the turn stalk on the column. its not as bad as you might think to change.
  3. #3 Re: Having a problem with lights
    St. Louis
    I also had an issue similar to this on my 00 GT and I messed with the hazzard light switch (turned them on and off a fgew times quickly) and everything started working again. So far it hasn't done it again so not sure what it fixed but I'm not messing with it, lol.
  4. #4 Re: Having a problem with lights
    Oct 2014
    portland oregon
    If you have changed any bulbs before your issue arose recheck the install.
    I flipped a bulb once and it made everything haywire.
    A dab of bulb grease before you put the bulbs in is a good way to get good connection prevent corrosion make them easier to remove down the road
    Sent from my SM-N910V using Tapatalk
  5. #5 Re: Having a problem with lights
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    I've had the same issue on my 2000 before, it was the multifunction switch. Our brakelights also run through that switch. (Except the highmount 3rd light I believe)
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  6. #6 Re: Having a problem with lights
    Nov 2017
    WV
    btw I forgot to post it.. i drive a 97 Gran Prix SE... I have noticed that the rear light lenses collect a lot of water in them. I will try these tips first.. thank you.
  1. Cps problem but with lights.
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2013, 06:22 AM
  2. Dashboard lights problem???? Anyone can help me plz???
    By amakarow in forum Introductions/Noob Questions
    Last Post: 01-03-2013, 04:52 PM
  3. Problem with tail lights
    By Batmobile gp in forum General Grand Prix Discussion
    Last Post: 12-14-2012, 05:17 PM
  4. New LED reverse lights problem
    By hockeybawler in forum Visual/Body Modifications
    Last Post: 02-07-2012, 12:55 AM
  5. problem with the interior lights?
    By riseagainst4288 in forum General Tech Discussion
    Last Post: 07-24-2009, 08:37 PM
