Thread: No CEL when MAF sensor going bad
Results 1 to 7 of 7
NotEnoughGPs No CEL when MAF sensor going... 10-29-2017, 04:39 PM
FordMan77 Re: No CEL when MAF sensor... 10-29-2017, 05:12 PM
BillBooost37 Re: No CEL when MAF sensor... 10-29-2017, 06:26 PM
NotEnoughGPs Re: No CEL when MAF sensor... 10-29-2017, 08:05 PM
231FUN Re: No CEL when MAF sensor... 10-29-2017, 08:34 PM
Scottydoggs Re: No CEL when MAF sensor... 10-29-2017, 08:37 PM
wstefan20 Re: No CEL when MAF sensor... 10-30-2017, 04:30 PM
  1. #1 No CEL when MAF sensor going bad
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    It has happened again.
    This is 2 times this year in 2 different GP's that I have experienced all sorts of problems with stalling, no starts, missing, loss of power, boost gauge showing full boost when barely touching the gas pedal, etc. I was checking all sorts of parts on the car and replaced a fuel pressure regulator, and removed and cleaned all kinds of parts.
    But even though I was aware of the fact that the Mass Airflow Sensor could be bad, and was told to check the MAF, in my stupidity, I still did not swap the MAF out. I figured there was no check engine light on.
    Well, to make a long story short, I installed a good MAF into a GTP that was running very poorly and stalled and would not start. As I went to start the car on the 2nd try, it fired right up and has been running almost perfect. The bad MAF was in the car when I bought it, and I would have saved myself lots of stress and loss time if I would have replaced it on the 1st day I got it home.
    So, learn from my mistake that if you are experiencing any issues with starting, idling, missing, or whatever, make sure there is a full functioning MAF sensor in place. The CEL will not alert you to a MAF sensor going bad.
  2. #2 Re: No CEL when MAF sensor going bad
    St. Louis
    Yep, also make sure the wiring going to it is good. And don't go aftermarket on the MAF, get a OE GM one as the others seems to be hit or miss on if they will work or not.
  3. #3 Re: No CEL when MAF sensor going bad
    Mar 2017
    Internet
    my favorite test is to tap on it with a fingernail while it's running. it the engine spits, sputters or stalls..it's a maf
  4. #4 Re: No CEL when MAF sensor going bad
    Aug 2013
    Pittsburgh, PA
    Hey, as far as getting a new MAF sensor for the Grand Prix, what model years are compatible with each other? Is it 1997-1998 models have one MAF that works for both years, and then there is a MAF for the 1999-2003 years?
  5. #5 Re: No CEL when MAF sensor going bad
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by NotEnoughGPs View Post
    1997-1998
    1999-2003
    2004-2008
  6. #6 Re: No CEL when MAF sensor going bad
    its part # is right there on top of it, match it up. they came in many gm cars. na or sc.
  7. #7 Re: No CEL when MAF sensor going bad
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I have a spare oem sensor lying around, so if you need one, just pm me.
  1. Replies: 7
    Last Post: 01-31-2015, 07:12 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
