Thread: Barely Getting Hot Air
Results 1 to 2 of 2
  1. #1 Barely Getting Hot Air
    Oct 2017
    Virginia
    NOTE: I actually don't own a Grand Prix - a friend of mine who doesn't use a computer has one and asked me to post a message for them to help them troubleshoot a problem they're having. So any replies might take longer than usual since I only see them a couple of times a week.
    I'm trying to get my 2004 Pontiac Grand Prix to throw out hot air, but it's just barely throwing out heat. I've put a thermostat in it. I've also put a new switch on it that controls the hot and cold air. On top of that, I checked the hot water hose that goes into the heater coil (so it's circulating). There's no visible leak on the hose. But still no hot air.
    If anyone knows what the problem might be, let me know. Thanks in advance for your help.
  2. #2 Re: Barely Getting Hot Air
    if both heater hoses are hot when up to full running temp the core is ok, if one is hot or cold or both are just warm, you got air in the core.
    if theres no air trapped in the core its a blend door actuator. http://www.grandprixforums.net/threa...or-Replacement
    you can take them off and turn the little knob by hand to see if you get heat when turned. it dont move much, so dont go trying to make it turn more then a 1/2 inch either way.
  1. Replaced harmonic balancer now it barely runs
    By robinsone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2015, 07:06 PM
  2. Car starts and then just barely idles
    By KTM300 in forum General Grand Prix Discussion
    Last Post: 07-27-2015, 08:00 PM
  3. Barely gets up to 30mph??
    By jckmcghie in forum Introductions/Noob Questions
    Last Post: 05-09-2013, 10:10 PM
  4. 2005 GP GT: A/C barely blowing cool air
    By winterstorm in forum General Tech Discussion
    Last Post: 08-15-2012, 12:45 PM
  5. Engine revving but barely moving
    By MBigelow in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-10-2011, 04:02 PM
