Thread: blower motor
Results 1 to 20 of 23
  1. #1 blower motor
    GT Level Member Chleby's Avatar
    Sioux Falls, SD
    so right now my blower motor isn't working...I got it out and put my multimeter to the leads going to it and on speeds 1-4 i get 14v and on 5 I get 0....at first I had all speeds but 1, then I lost 5 and now none work...could it be the resistor i got a different motor and it didn't help...anything will help thanks
    I have an '01 GT if that matters
    2001 Grand Prix GT...turbo build soon to come
    http://www.cardomain.com/ride/2618949
    Andrew Chleborad....Sioux Falls, SD
  2. #2 Re: blower motor
    Sioux Falls, SD
    I forgot...also is there a good way to test the motor?
  3. #3 Re: blower motor
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    you can test the motor by using leads and connecting to the battery.
    yes, the resistor can cause this situation that you describe. My resistor was slowly going, first no 1, then 2, then 3/4. used it on 5 exclusively for a few months, but then one day, it stopped working all together. i replaced the resistor and it's working fine now.
  4. #4 Re: blower motor
    Sioux Falls, SD
    something doesn't seem right though cuz I got voltage goin to the motor but it's not workin for some reason....maybe i'll try the resistor and see if that works
  5. #5 Re: blower motor
    SW Chicago Suburbs
    mine was the same way.
  6. #6 Re: blower motor
    Sioux Falls, SD
    problem solved lock if desired....wil pry do a write up for the blower motor as well as the resistor replacment if there isnt already
  7. #7 Re: blower motor
    PA
    So what was the problem? How did you solve it? Just give a short write up here for anyone searching these threads. Just what you found or what you changed.
    Glad you got it working!
    2001 GSE
  8. #8 Re: blower motor
    Sioux Falls, SD
    I cahnged out the blower motor out (probably didn't have to but the old one was rusty so Idid it anyway and cahnged out the blower motor resistor which was the acctual problem...total of 4-5 bolts to take out depending on how hard you want to work.
  9. #9 Re: blower motor
    NY
    yea, when the seal at the cowl starts leaking it goes right in to the blower and resister unfortunately
    2001 Regal-GMPP handling, shift kit, tuned, ported Gen3, 3.6, N*, SLP dual catback, Aeroforce
    70 Monte Carlo 12.5@109 waiting on new setup
  10. #10 Re: blower motor
    PA
    Make sure you put in a cabin air filter. They never put these in GPs from the factory, but the regal one fits just perfect. And it keeps some moisture from getting in and rusting your blower motor.
    2001 GSE
  11. #11 Re: blower motor
    Sioux Falls, SD
    I'l have to do that...well when it warms up at least..it was like 10 degrees out when i did this and my garage isn't heated and it's just gotten colder
  12. #12 Re: blower motor
    PA
    Quote Originally Posted by Chleby View Post
    Yeah, I know what you mean. I am trying to work on my car in my unheated garage with one small heater. It has been running all day and only up to 40 in the garage.
    But also a good idea because you have to bend the plastic cowl a little and if it is cold, it could snap pretty easily.
    2001 GSE
  13. #13 Re: blower motor
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    Be glad you have a garage! I dont. I had to replace a wiper a few days ago. Now the window is broke. I can't win! Feel sorry for me at any time now
  14. #14 Re: blower motor
    SE Level Member Blue03GTP's Avatar
    Wi
    Is there a writeup for this somewhere? I have the same issue.
    Blue 2003 Limited Edition.
  15. #15 Re: blower motor
    SE Level Member deangtp's Avatar
    Kansas City, MO
    yeah do a writeup cuz im in the middle of trying to figure out my freakin fans right now. i bought a resister and cant figure out where it goes, bought a control module and it didnt fix the problem and i got a blower motor coming tomorrow
  16. #16 Re: blower motor
    SE Level Member azzkikr1957's Avatar
    Apr 2008
    Hi all just wanted to let ya know that I had to do this to my 2000 GT. it was hard getting the bolts out, but i got them, putting the blower resister modual in was a lot easyer. total cost was $175. and a lot of sweat.
    p.s. took front passenger seat out to help with removal too.
  17. #17 Re: blower motor
    Beckley, WV
    I have 98 GT. Resistor modul bad. Found new one for $30. Hooked the blower up in the floor and the it works good on all speeds. Now I have to put it all back together. I would like to remove the front pass. seat to make it easier to get to the stuff. Trying to figure that out now. Resistor module was hard to get to the screws (3) holding it in. I took everything out with the front seat in but it was not comfortable. Shirley if I can get all that crap apart with it in, I can figure out how to remove the seat for the re-install.
  18. #18 Re: blower motor
    Barksdale AFB, LA
    Quote Originally Posted by ljsimpkins View Post
    Of course you can, and don't call me Shirley.
    2009 Subaru Impreza WRX STI
  19. #19 Re: blower motor
    Wausau, WI
    Quote Originally Posted by Sabrewings View Post
    Shirley, Shirley, Shirley.......na na na na na.....
  20. #20 Re: blower motor
    Beckley, WV
    Here is the deal for all you mechanical wizards out there. (98 GT, 3.8l, manual air control) Please advise.
    I changed the resistor. Plugged the motor up while laying in the floor. I was happy, motor ran on all 5 speeds. The next day I got the front seat out and very comfortably put the resistor and motor back in. Turned the key on and the same thing happened, motor only runs on high speed (5). I've got voltage (11+ volts) at the motor leads in all 5 speed settings, so why wont the motor run in all speeds? So I go back to the parts place and get a new motor, plug it in (setting in the floor), get the same thing, motor only runs in speed 5??? Dang, I'm gittin frustrated. So someone suggests maybe I fried the new resistor some way so I go get another brand of resistor (made in Slovenia), plug it in, same deal, only runs on speed 5. There has to be a solution here but I'm getting old and would like to get it fixed so I can ride the GP to the nursing home. I'm looking at fuses today but since I have power at the motor leads I doubt that would have anything to do with it. By the way , the rear window defogger has never worked from day one? It looks to me like "Government Motors" has lost another customer in their "not so bright" future.
  1. rear window regulator/motor install write up
    By ExpyGator in forum General Tech Discussion
    Last Post: 11-17-2009, 12:52 PM
  2. 97 blower motor wont fit a 99
    By ryangtp89 in forum General Tech Discussion
    Last Post: 01-01-2008, 12:14 AM
