whats the light issues? sounds like a bad ignition harness.
Fog lights won't come on. Indicator light on fog switch doesn't light.
Interior dome/courtesy lights [including trunk] don't work, tracked that down to a pulled fuse. When fuse is replaced, they stay on at all times.
Blower motor will continue running with IGN off. All 5 speeds.
PO has run a jumper wire from the brown on exterior pass side turn signal bulb socket leading to inside fuse box, bare end under DRL fuse.
DIC will dim/brighten along with turn signals.
Headlights seem incredibly weak.
