Also I'm totally mind f*cked and I need help. This kit I got was missing lines from the solenoids to the fogger. I thought just to buy 3an hose but I drove 30 miles to a hose shop and apparently the fogger and fitting on the solenoids are compression fittings so I have no idea what hose to get or if I should just switch to an fittings. This kit originally came with 1 hard line on the fuel solenoid out so I'm assuming this kit was originally for a carb setup. Also I had to swap the "in" fitting on the nitrous solenoid because it was a compression fitting but the long 14ft hose that came with the kit was a standard 4an. So basically this is a whole clusterf*ck. So basically can I switch all the fitting to an or do I need to keep the compression fitings on the fogger because the jets won't fit in an an fitting? What hose do I buy for compression fittings?
Sent from my LG-H918 using Tapatalk
