Make sure your ignition relay is fully seated. If it is swap it out with the headlight relay and see if it starts. Like 5FDP said do a security relearn regardless. If that doesn't work check the connection pins at the ICM harness and be sure none of them are bent or pushed out of the harness. If none of this works look for a ground or connection left loose.
