What do you mean by "We corrected the fuel pressure"....? What did you do and why did it not have fuel pressure to begin with?
Also by "tested the ignition control module" how did you test, and are you getting any spark at the coil packs?
I know one common thing to do is forget to reconnect the crankshaft position sensor wire or the ground to the icm bracket. Both run under the bracket and are fairly easy to leave off.
