Thread: Replacement rear view mirror
Results 1 to 6 of 6
  1. #1 Replacement rear view mirror
    Jun 2016
    n/a
    Hey all,
    I'm looking for info on auto-dimming rear view mirrors for a 98 gtp. Mine’s broken and I’d like to replace it. I like the auto-dim feature so I’d like to stick with that if possible.
    I’ve searched and seen many posts on the topic but they are all pretty old, so I’m just looking for some current info.
    I’ve seen posts talking about the fluid leaking out. Is this a problem with new replacements, or just when the old factory mirrors break?
    Is it worth it to install a new auto-dimming mirror or should I simplify and go with a classic manual?
    What is the best stock-for-stock replacement?
    Thanks in advance for any input you can provide!
  2. #2 Re: Replacement rear view mirror
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    There's a member on here that's an expert on rear view mirrors for these cars. He's not online as often as he used to be, but send him a message. He will sell you one.
    Name is: RareGMFan
    http://www.grandprixforums.net/threa...r-view-mirrors
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  3. #3 Re: Replacement rear view mirror
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    All run the risk of leaking. Its the design of the company that makes them.
    Mine went and I replaced it with one from a maxima. It had the auto dim, home link garage door openers, and a compass. Compass only worked in reverse though. Never bothered to really figure ou why.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  4. #4 Re: Replacement rear view mirror
    GT Level Member mguzzo's Avatar
    Buffalo NY
    My 1998 had the stock Donnelly mirror with three wires: Yellow is power, Black is ground, and green is autodim inhibit. this is so the mirror will not dim when the car is in reverse. I got a Onstar mirror with a 16 pin connector and had to splice it in.
    16 pin: (*required; **required if you have a temp display)
    * 1 = Grey = not used
    * 2 = Bare = Microphone
    o OnStar Mirrors
    * 3 = = "Passenger Air Bag on" notification
    o some GM trucks - ground pin to activate icon
    * 4 = = "Passenger Air Bag off" notification
    * 5 = = auto day/night signal from LH outside mirror
    o If you have a dimmable mirror, the rearview mirror can dim it with this and pin 16
    * 6 = Brown = Temp probe connection**
    * 7 = Green/Black = Temp probe connection**
    * 8 = Black = Ground*
    o Common to Pin 9
    * 9 = Light Green = Reverse Dim Inhibit
    o Common to Pin 8, +12V from reverse lights to disable dimming
    * 10 = Gray = Microphone
    o OnStar
    * 11 = Dark Green/White = keypad signal (out)
    o OnStar - multiplexed signal
    * 12 = Light Green = keypad +5v supply (in)
    o OnStar
    * 13 = Yellow = +12V switched (ignition)*
    * 14 = Yellow/Black = Green LED signal
    o OnStar - apply 12v to light LED.
    * 15 = Brown/White = Red LED signal
    * 16 = = day/night signal to LH outside mirror
    o If you have a dimmable mirror, the rearview mirror can dim it with this and pin 5
    So I took the old mirror off and took down the sunroof switch bezel to access the wiring. Snipped the mirror wires (no connector) and pulled the mirror out. I installed the new mirror, it fit the shoe fine but I had to find a #8 machine screw to lock it into place. Ran the wires up into the headliner and spliced in
    Car yellow -> pin 13 power
    Car black -> pin 8 ground
    Car green -> pin 9 inhibit
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: Replacement rear view mirror
    SE Level Member 02GTP 91WS6's Avatar
    Sep 2017
    NE Ohio
    I haven't had the issue on my GP, but my old 98 Chrysler Sebring had a fluid leak like that in their Donnelly mirrors. 9 times out of 10 it stays contained inside the housing but it does contain Mercury, so open it at your own risk. Eventually it'll dry and obstruct vision in the mirror itself.
    If your car already has the provisions for the compass and everything, then it's up to what you want to spend really. Auto dimming is nice but not a huge deal to me. Also know that OnStar on cars that age are completely obsolete and won't work as is.
    Sent from my XT1650 using Tapatalk
    2002 GTP coupe -- 2.9 pulley -- 2.25" IC -- N* TB -- Polished Gen V SC -- and more
    1991 Trans Am WS6 -- 350 crate -- shift kit
    2006 G6 GT Coupe -- Daily Driver
  6. #6 Re: Replacement rear view mirror
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I've still got my old mirror from when I upgraded to the onstar mirror if interested. Although, I see these mirrors all that time at my local junkyard and they're pretty cheap too!
  1. Replacement passenger rear view mirror
    By Fahrenheit in forum Visual/Body Modifications
    Last Post: 07-27-2013, 02:06 AM
  2. ? About reAr view mirror in 97 gtp
    By jteske88 in forum Audio, Security & Visual Electronics
    Last Post: 04-13-2011, 02:20 PM
  3. Rear View mirror tab
    By Toasty in forum General Tech Discussion
    Last Post: 02-17-2008, 12:48 AM
