Thread: bad window regulator
Results 1 to 4 of 4
alok bad window regulator 09-05-2017, 08:31 PM
Fivefingerdeathpunch Re: bad window regulator 09-05-2017, 08:36 PM
Scottydoggs Re: bad window regulator 09-05-2017, 08:38 PM
green97 Re: bad window regulator 09-06-2017, 09:05 PM
  1. #1 bad window regulator
    Feb 2016
    North Carolina
    Got info from here about replacing my window regulator. I'm wondering why when a window regulator goes bad the window decides to drop down and not simply stay up until its repaired ?
    I thought maybe liability issues on part of manufacturer ( in this case GM ) ,since you'd want the window to go up / down properly at all times ???
    But its broke !!!
    I know that , instead somebody could break into your car by sliding window down from outside ??? I guess if it stayed up you could as owner of the car forget about fixing it ,especially if it is a back window like mind ,that very rarely is used ,going up or down ???
    Until I repair it any good way to keep it from dropping down, tape is not working. I tried mounting tape on sides . . . is there a better place ?
    Al
  2. #2 Re: bad window regulator
    Block of wood inside the door.
  3. #3 Re: bad window regulator
    the cable broke, why it dropped. ive done the block of wood trick as well. works great to keep it up till you get a new regulator.
  4. #4 Re: bad window regulator
    SE Level Member green97's Avatar
    Jul 2011
    Eastern Idaho
    Use tie wire inside the door to hold it up, it is the most secure. Wood might work too.
  1. Window regulator
    By commander fistfighter in forum General Tech Discussion
    Last Post: 04-30-2017, 09:16 PM
  2. Window regulator
    By chevyy1212 in forum For Sale - Parts
    Last Post: 11-08-2014, 07:10 PM
  3. Window Regulator?
    By Lucid Violence in forum General Tech Discussion
    Last Post: 06-08-2010, 10:21 PM
