Thread: 2008 GP P11245, P2120, P2125, P2138 need some help
Results 1 to 7 of 7
  1. #1 2008 GP P11245, P2120, P2125, P2138 need some help
    Mar 2015
    Malta, MT
    I had these 4 codes show up car went into reduced power, was able to clear the codes and go on but now no dice. Changed TB and no luck, then pedal and no luck. I two wires at the pedal that have 5 volts unblocked but when attached voltage was no longer the same. I cant find any wiring diagrams so that I can chase it back. Found one set of grounds below the air cleaner on the block. It must be a bad connection but not sure where to start. Any help would be awesome.
    Thanks Rick
  2. #2 Re: 2008 GP P11245, P2120, P2125, P2138 need some help
    on the side of the tb is a part #, you need the same one or it wont work right. seen it happen to another guy here who did a engine swap and figured he'd just use the tb on the new engine, but he ended up having to use the old one off the blown engine.
  3. #3 Re: 2008 GP P11245, P2120, P2125, P2138 need some help
    Mar 2015
    Malta, MT
    So I seen different numbers on each one, there was a laser etched set of numbers. Do you know what i'm looking for?
    Thanks Rick
  4. #4 Re: 2008 GP P11245, P2120, P2125, P2138 need some help
    its on the electronic part on the side where you plug it in.
  5. #5 Re: 2008 GP P11245, P2120, P2125, P2138 need some help
    Mar 2015
    Malta, MT
    FIXED Bad ground from the pedal at the TB. It was backed out of the connector a bit. Always had an occasional issue with starting. Cheap repair if you don't count the headache and hair pulling. Thanks for all the help.
    Thanks Rick
  6. #6 Re: 2008 GP P11245, P2120, P2125, P2138 need some help
    Dec 2014
    Montreal, Canada
    Hey hello Mtbuicknut. I am having the same issue. when you said "it was backed out of the connector a bit" are talking about the connector at the TB or the connector at the pedal?
    I did not replace anything yet cause from all the forum post I have read, no one has fixed there problem by replacing the TB or the throttle pedal assembly so before spending money on part I did cleaned the TB witch was very dirty. I erased the code and it came back 3 days later. Then I check the wire at the connectors witch look find but I cleaned the connector anyway.
    Maybe I did not check the wiring deep enough so maybe there is a weak spot in the harness so why I am very interested to know where your bad ground was exactly please.
    Thanks
    Rick
  7. #7 Re: 2008 GP P11245, P2120, P2125, P2138 need some help
    Dec 2014
    Montreal, Canada
    Quote Originally Posted by rickwr88 View Post
    Thanks
    Rick
    I have been thinking correct me if I am wrong please. If the pedal throttle assembly was misreading or malfunctioning will it still be able to make the passing gear get on? I did some test when driving with the code "ON" and the passing gear get on as usual and the throttle seems pretty accurate when raving the car on neutral which make me think it is the throttle body or the electrical around it... chasing a bad wire in the harness is pain in the ass duty...
  1. P1125 and P2138, replaced pedal won't go away
    By Metal Links in forum General Tech Discussion
    Last Post: 07-29-2017, 07:12 PM
  2. 2004 gt accelerator position problem with codes p1125, p2120, p2138
    By 2004 GT GIRL in forum General Grand Prix Discussion
    Last Post: 09-30-2016, 03:15 PM
  3. 2008Grand prix fault codes p1125-p2120-p2138
    By daviddawg in forum Introductions/Noob Questions
    Last Post: 04-04-2014, 02:10 PM
  4. NEED HELP: Codes popped P1125, P2120, P2125, P2138, P0401, P0068 and P0101
    By deejayfb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2013, 04:17 AM
  5. P2138 P1125 codes
    By jlusleton in forum General Tech Discussion
    Last Post: 09-23-2011, 05:35 PM
