Thread: '97 Wheel bearings & brakes & rotor questions
Results 1 to 20 of 29
  1. #1 Re: '97 Wheel bearings & brakes & rotor questions
    St. Louis
    The big rubber mount is the subframe bushing. The large chunk of steel that it is a part of is the subframe. It's what the motor and trans is bolted to. It's the same thing that you use to jack the front end up with. I'd just set the stands on that at the corners and call it done. I'd hate to see the stands go through the body at the pinch welds on ya.
  2. #2 Re: '97 Wheel bearings & brakes & rotor questions
    Aug 2017
    where the rust is
    Quote Originally Posted by FordMan77 View Post
    Yeah, I think I'll go this route, seems to be the safest, was seeing how bad the rust was, and I could use a small nail to push through parts of it.
    For the rust, do I bother spraying it with rust inhibitor, the clear stuff that turns the metal black? I don't recall what the brand name is.
  1. How to's for Brakes, Bearings and oil and transmission fluid changes.
    By cameron92 in forum How To Write-Ups/Tech Tips
    Last Post: 12-03-2014, 07:29 PM
  2. wheel bearings
    By whit in forum General Grand Prix Discussion
    Last Post: 09-19-2012, 05:58 PM
  3. Rotor Pack Bearings
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2011, 05:13 PM
  4. M90 Rotor Bearings
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 02:17 PM
  5. Rotor pack bearings
    By marchi1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2008, 05:36 PM
