Is there a way to do a fuel pump relay bypass on a 2002 gt to run it at high speed? I've done the 'bend tab 85' before on my gtp's when having problems with low end fuel issues-- but not sure if a gt pump is wired the same. Trying to rule out fuel pump as cause of my latest problem. Car idles fine for a few minutes of driving then vacuum starts to drop and motor starts surging to the point of stalling. If I'm above 3000 rpm it seems to be able to continue running, not great but at least drive-able. Can't find any vacuum leaks and unplugging maf didn't seem to help.
