Thread: Headlight lens Problem
Results 1 to 2 of 2
  1. #1 Headlight lens Problem
    Aug 2017
    Massachusetts
    Hi, I have a 08 Gran Prix,base. I have purchased 2 sets of lights over 9 years. My new set, is starting to oxidize in top corners of lights. Sorta like inside plastic distorting? All inside,not outside. No moisture,but heavy clouding up? Two different companies for lights. Is this common? Thanks.
  2. #2 Re: Headlight lens Problem
    Pennsylvania, USA
    You're certain it's on the inside? Aftermarket lenses tend to lose their UV protectant pretty quickly, it sort of peels and then begins to oxidize.
    That said, I've had some A/M lights gather condensation internally, the lens wasn't fully sealed. I tend to run a thin spread of clear silicone over the seam where the lens seals to the base. They've never clouded because of this though, it's always been the exterior of the plastic oxidizing.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  1. 97+ Lens out of headlight assembly
    By Ninny in forum Visual/Body Modifications
    Last Post: 08-29-2013, 01:26 PM
  2. Headlight lens replacement
    By mckillin in forum Visual/Body Modifications
    Last Post: 02-21-2013, 12:26 PM
  3. headlight lens plastic or glass?
    By Joe m in forum General Tech Discussion
    Last Post: 01-29-2010, 06:58 PM
  4. headlight lens
    By david hagaman in forum General Tech Discussion
    Last Post: 04-13-2009, 02:17 PM
  5. headlight lens and housing
    By TDCRacing in forum Shops and Community Heroes
    Last Post: 08-30-2008, 01:14 PM
