Thread: GP sedan rear passenger window will not go up/down
Results 1 to 6 of 6
  1. #1 GP sedan rear passenger window will not go up/down
    Feb 2016
    North Carolina
    I got a 2002 GP GT.
    Last night got home and noticed my rear passenger window was down about 3 inches. Try to put it up via window up/down switch I only heard a small short noise burst in that door in up & down mode ... but window did not move either up or down.
    I was able to push window up & close it ,from outside ,as well as make window go all the way down from outside ,by pushing it down ... not good.
    What is wrong and is it an easy fix I can do, any special tools needed ?
    Al
  2. #2 Re: GP sedan rear passenger window will not go up/down
    Sounds like the cable is broken.
    I'd go and buy a new window regulator and test the motor first. Regular hand tools can do this whole job.
  3. #3 Re: GP sedan rear passenger window will not go up/down
    GTP Level Member
    Oct 2014
    You can get the whole unit on Amazon for like 40 bucks.
  4. #4 Re: GP sedan rear passenger window will not go up/down
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Easy, I believe all you need is a 10mm socket. http://www.rockauto.com/en/catalog/p...assembly,15596
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  5. #5 Re: GP sedan rear passenger window will not go up/down
    Feb 2016
    North Carolina
    I see prices from about $40 to $100 , what is a good type ( in the low to mid price range ) that most have used here for replacement and are happy with ... I plan to keep car at least 3-5 more years.
    What I found odd was I hardly ever use the back windows ... and yet it was a back window that failed. I've heard since I got the car in 2002 that the window regulators were not too great on GM cars ... but they've all worked perfect for 15 years.
    Al
  6. #6 Re: GP sedan rear passenger window will not go up/down
    GTP Level Member
    Oct 2014
    I got the cheapest ones. Still work a year later.
  1. Rear passenger window disengaging
    By Bobpass in forum Visual/Body Modifications
    Last Post: 08-30-2016, 06:52 PM
  2. Rear Passenger Window Motor
    By UCF04GPGTPCompG in forum Visual/Body Modifications
    Last Post: 07-02-2011, 10:06 PM
