If you’ve been following my re-build thread in the “Members Rides†section, you’ll know I have a new rack/pinion and new outer tie-rods. I’m about to install the outer tie-rods but not certain about the correct order of operations here. I know an alignment will be required, but first I need to hook everything up. Question is:
Should I first thread the outer tie-rod to the inner tie-rod, and then put the stem in the knuckle and secure with castle nut?
Or, should I put the stem in the knuckle first, secure with castle nut, and then turn the inner tie-rod till it connects with the outer one?
Seems like the first option is best when I tried sizing things up last night, just wondering though.
Also, isn’t the geometry of the tie-rods gonna change once the wheels are on the ground? Here’s what I mean. The LCA’s and knuckle and just hanging there right now. Once I lower the car to the ground, the LCA’s will go up and sit about even with the sub-frame. I’m assuming the knuckle will rise slightly as well. Will that mess anything up? Will the outer tie-rod be jamming the inner tie-rod into the rack?
Might be over-thinking this. Let me know. Thanks.
