Thread: 08 GP Base Totally Dead This AM
Results 1 to 9 of 9
  1. #1 08 GP Base Totally Dead This AM
    GTP Level Member
    Aug 2012
    st louis park, MN
    I went to start my 08 grand prix base model (150k miles) this morning and it turned over like normal for about 1/4 - 1/2 second then just totally dead. When I when to restart - no lights on the dash, no fuel pump prime, nothing I could even sense.
    If I turn and hold the key in the crank position, the little engine light will flash rapidly a few times after maybe 5 seconds.
    Can anyone help me troubleshoot this? I'd really like to take a shot at this yet today and my only thought is crank position sensor.
    If you have any experience please post up - I'd even call you if possible.
    Thanks in advance - hope someone can help!!!
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  2. #2 Re: 08 GP Base Totally Dead This AM
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Disconnect the batt for 10 mins.? That's free and fast....
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  3. #3 Re: 08 GP Base Totally Dead This AM
    clean the battery terminals, make sure the ground is good.
    also make sure your bat cables are good. if you see bare wire at the end you likely need a new cable.
  4. #4 Re: 08 GP Base Totally Dead This AM
    GTP Level Member
    Aug 2012
    st louis park, MN
    Is the ground just off the cables bolted to the frame somewhere? Thanks so far guys, I'm going to go try right now.
    Other thoughts?
  5. #5 Re: 08 GP Base Totally Dead This AM
    neg cable bolts to the trans bell housing, right near the starter. id start up top at the battery tho.
    try a jump start yet?
  6. #6 Re: 08 GP Base Totally Dead This AM
    GTP Level Member
    Aug 2012
    st louis park, MN
    Its the battery connection. Those ****ty closure systems are not locking down on the terminals anymore - loose connection. They won't lock on, any thoughts on this?
    I'll take a closer look myself as well. Thanks guys
  7. #7 Re: 08 GP Base Totally Dead This AM
    Aug 2016
    CT/RI Border
    Two methods, appropriate and slightly more expensive or cheap and dirty.
    Slightly more expensive is buy new cables and route them.
    Cheap and dirty, get a hacksaw, cut the old terminals off as close to the bad connector as possible and replace with cheap universal replacements.
    Sent from my ASUS_Z00TD using Tapatalk
  8. #8 Re: 08 GP Base Totally Dead This AM
    GTP Level Member
    Aug 2012
    st louis park, MN
    I'm going to try the new nuts first. Hopefully those are the worn item not the terminals themselves.
  9. #9 Re: 08 GP Base Totally Dead This AM
    GTP Level Member
    Aug 2012
    st louis park, MN
    It was the battery nuts.
  1. Not totally new here...
    By LilRdFiero in forum Introductions/Noob Questions
    Last Post: 09-29-2013, 03:09 PM
  2. Took a gamble...totally paid off.
    By Peacher213 in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2012, 04:27 AM
  3. 01 Grand Prix has me totally baffled. Please help!!
    By 1taylor2few in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-09-2010, 08:24 PM
  4. '01 3800 N/A won't start! totally confused...
    By Ragefear in forum General Tech Discussion
    Last Post: 04-04-2009, 10:06 AM
  5. I truly am totally nuts.
    By Ron Vogel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-20-2008, 04:09 AM
