Thread: Best window regulator manufacturer for coupe´?
Results 1 to 4 of 4
  1. #1 Best window regulator manufacturer for coupe´?
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Hey guys Ive gone through 5 window regulators in this past year which is partially my fault for buy cheap Chinese brands but after all the pain in the ass its been I'm willing to spend real money on some regulators. So what's the best? Acdelco at 90$ per side or is Dorman good at 70$ per side?
    Sent from my LG-H918 using Tapatalk
  2. #2 Re: Best window regulator manufacturer for coupe´?
    St. Louis
    I usually use OEM Delco when I can afford it. Then I lube it with lithium grease before install. Also make sure that the felt window guides and dew wipes on both sides are clean. I also used a dry graphite spray on the channels when I installed my last ones which seemed to help a bunch. If you have tinted windows just be sure not to spray it anywhere but the side channels or it might mess up the tint.
    Not sure what year coupe you have, but RockAuto is showing ACDELCO 11R26 {#19251075} Professional front left coupe regulator for $55.79 and front right ACDELCO 11R25 {#19251074} Professional for $62.79. This doesn't include the motors. If you search the net you can likely find at least a 5% coupon to RockAuto as well.
  3. #3 Re: Best window regulator manufacturer for coupe´?
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I second ford man on that recommendation. Haven't tried graphite spray yet, but I've always been successful with silicon lube. Probably isn't much difference.
  4. #4 Re: Best window regulator manufacturer for coupe´?
    Jul 2016
    St. Louis
    If you have a local Pink N Pull, that's where I'd be getting one from. There are several around me and they charge right around $20.00 for the complete set up.
  1. Need Window regulator for 99 coupe
    By DrSnazzy in forum Wanted To Buy - Parts
    Last Post: 07-29-2013, 09:44 PM
