Thread: Choosing a catback!
Results 1 to 20 of 29
  1. #1 Choosing a catback!
    SE Level Member Blacknitews6's Avatar
    May 2017
    south jersey
    I'm about ready to start modding a 2000 Grand Prix GTP.
    The mains i want:
    ZZP Z7 turbo kit
    ST2 cam
    And i like ZZP's 3" catback, well almost. From what i heard on youtube i wasn't impressed with the sound of it. I love that it's stainless,
    but i just don't like the sound of the mufflers. Can you guys give some ideas what mufflers others are using? I prefer a stainless
    muffler. I appreciate everyone's advice.
  2. #2 Re: Choosing a catback!
    St. Louis
    Factory stock ones. And keep the resonator in place as well. Other than that, maybe Borla's come to mind
    Youtube search for 3800 exhaust and see what comes up. Most of the mufflers on these cars will make it sound like junk so def. do some research. After all, it's your ears that have to hear it, lol..
  3. #3 Re: Choosing a catback!
    GTP Level Member buickman104's Avatar
    NYC
    Also the drone is unbearable!@
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  4. #4 Re: Choosing a catback!
    May 2017
    south jersey
    I emailed Tim to see if he could given any ideals what mufflers i can buy to replace the ZZP mufflers in their 3" system.
    He gave some other great advice, but just said their 3" kit sounds better in person that on youtube. I told him i would like a little rasp. The ZZP has really no sound, just a loud humming tone.
    If anymore of of you guys think of anything else i should do, please lay it on me. And i'm adding a Z7 kit, and the ST1 or ST2 cam, I don't to buy a ton cabacks to find the best one. I'm thinking with just going with SLP even though it's 2.5" catback because it has an aggressive enough tone. An you can hear the cam crackle out the exhaust.
  5. #5 Re: Choosing a catback!
    zzp and the slp both sound like crap......you could buy that mandrel bent 3 inch pipe kit and add mufflers for less.
  6. #6 Re: Choosing a catback!
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    This. Mandrel Sysytems/TruBendz stainless pipe is $270 for the dual kit. Add your own res and mufflers, ftw.
    SLP is known to be loud and very anus-sounding. Also, try and view vids that are more than just the idle. Drone's a B on long trips.
  7. #7 Re: Choosing a catback!
    Kemmerer, Wyoming
    here is an actual site that has a compilation of exhaust's.
    http://wbodyexhaust.com/
    and this site here sells catback exhaust kits, if you get a 3" stainless steel it is like 345, but then you need to add mufflers and a resonator.
    http://www.mandrelexhaustsystems.com...ng-system.html
  8. #8 Re: Choosing a catback!
    May 2017
    south jersey
    Quote Originally Posted by SgtMarshal View Post
    I like that full 3" stainless exhaust tubing. I looked at the Hooker 21646HKR muffler:
    Just need a nice pair of dual stainless tips. and need to make sure everything lines up.
  9. #9 Re: Choosing a catback!
    if you're going turbo, just run a 3" straight pipe. the turbo will be the 'muffler'. I ran a side exit on mine old build.
    edit-the exhaust note on a turbo wbody is completely different than s/c setup.
  10. #10 Re: Choosing a catback!
    someone random recorded my run at KOTS event in cecil
    https://www.youtube.com/watch?v=Od-q...d54zx7C1Ii3nkQ
    short pull
    https://www.youtube.com/watch?v=MJ9s-F8t2Yg
    Idle...the cat converter is gutted btw
    https://www.youtube.com/watch?v=v-lcpLV2qvw
    On the dyno (cant recall the psi/timing setup unless its in the vid on low boost?)
    https://www.youtube.com/watch?v=0cftb9Ppbdo
  11. #11 Re: Choosing a catback!
    May 2016
    MN
    Somewhat on topic; I found this link the other day saved on the laptop. Apparently they've put into production, some kind of "adjustable" muffler that would fit the stock resonator spot.
    I'm not sure whether to lmao or not, lol.
    https://shop.patriotexhaust.com/patr...et-outlet.html
    What's up with that price?
  12. #12 Re: Choosing a catback!
    looks like an integrated e-cutout.
  13. #13 Re: Choosing a catback!
    Jul 2010
    Coquitlam,BC,Canada
    Make sure you have a resonator, and Borla mufflers sound pretty good.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Choosing a catback!
    If you have the $$$$ get the borla or corsa cat back.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  15. #15 Re: Choosing a catback!
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Exhaust is so subjective but my personal opinion is aftermarket on these cars sound terrible and drone like crazy. My friends SLP should have come with a bottle of Tylenol and ear plugs. It doesn't sound good to me. Just annoying. I like low, deep, and mellow and you just don't really get that with these cars. I did a Dynomax factory replacement cat back with Ebay cat and I like it. It is just a little louder than stock but still pretty quiet and no drone. It is a packed muffler not chambered. If you insist on going aftermarket I would only run Borla. Their packed muffler sounds much nicer than chambered.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  16. #16 Re: Choosing a catback!
    Nov 2011
    NY
    Mandrel Bend 3" Stainless to Vinrant Ultra Quiet Resonator (there's room for 2 if desired) to Hooker Max Flow Mufflers ending with dual stainless exhaust tips!
    Thats the exhaust... Lol
    if you want to stay close to stock, you can downsize to 2-1/2"...
  17. #17 Re: Choosing a catback!
    You're going to want a offset in and center out muffler too.
  18. #18 Re: Choosing a catback!
    May 2017
    south jersey
    Thanks, cause i wasn't sure how everything was gonna line up.
  19. #19 Re: Choosing a catback!
    Jul 2010
    Coquitlam,BC,Canada
    ^ This.
    Offset in, center out....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  20. #20 Re: Choosing a catback!
    May 2017
    south jersey
    Quote Originally Posted by Bronco Boy View Post
    ^ This.
    Man i love Borla as well. I had a Borla catback on my 1999 Camaro SS M6, and my 2002 WS6 A4. Love that exhaust. Thanks for the part numbers Bronco.
  1. Zzp catback exhaust or slp catback
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2017, 10:17 AM
  2. need help choosing a cam
    By lance4682 in forum General Tech Discussion
    Last Post: 05-07-2014, 07:13 PM
  3. Choosing the right (s)way
    By Axby523 in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2012, 05:04 PM
