So I replaced the leaking condenser. Pulled vac held it overnight. Went to recharge system and the o ring at the condenser blew out once it reached a certain pressure.
So I replaced the o ring and pulled vac. Held the vac overnight and then used those recharge cans. Refrigerant goes in and the compressor never kicks on. I jumped the compressor to the battery and it kicks on, but when I reconnect the connector it never kicks on. The gauge on my ac can says 70 psi.
Did I pull to much vacuum? What's going on? How I jump the pressure switch?
