Thread: Ac recharge question?
Results 1 to 5 of 5
  1. #1 Ac recharge question?
    Sep 2015
    Lansing, Michigan
    So I replaced the leaking condenser. Pulled vac held it overnight. Went to recharge system and the o ring at the condenser blew out once it reached a certain pressure.
    So I replaced the o ring and pulled vac. Held the vac overnight and then used those recharge cans. Refrigerant goes in and the compressor never kicks on. I jumped the compressor to the battery and it kicks on, but when I reconnect the connector it never kicks on. The gauge on my ac can says 70 psi.
    Did I pull to much vacuum? What's going on? How I jump the pressure switch?
  2. #2 Re: Ac recharge question?
    Sep 2015
    Lansing, Michigan
    When I hook manifold gauges it's reading 72 on low side and 75 on high side. This is without the compressor running because I can't get it to run
  3. #3 Re: Ac recharge question?
    GTP Level Member
    Jun 2016
    Cleveland ohio
    maybe the pressure sensor is bad. before you replace it trace the wiring into the harness. feel the wire for bumps, I have had several wires bad this way. You can also peel back some of that wiring from the top and look for corrosion.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  4. #4 Re: Ac recharge question?
    Sep 2015
    Lansing, Michigan
    I tried jumping the compressor again and I let it cycle for a minute or two... then I plugged the connector back in and the compressor kicked on. Now it's running normal lol. I put 24oz or refrigerant and the system was empty before this. It's blowing cold out of the vents, but isn't the capacity 36oz? It's an 02 gp 3.8
  5. #5 Re: Ac recharge question?
    St. Louis
    I always thought it was 1.88lbs, which is around 30oz. What is the ambient temp and humidity? What do the high and low side gauges read now?
  1. A/C PRO recharge kits
    By Madness in forum General Tech Discussion
    Last Post: 06-03-2014, 05:45 AM
  2. A/C Warm after recharge - Too much oil?
    By Matticus in forum General Tech Discussion
    Last Post: 06-11-2013, 06:00 PM
  3. AC recharge??
    By apierce1289 in forum General Tech Discussion
    Last Post: 08-14-2011, 10:07 AM
  4. AC Recharge
    By dreyescairo in forum General Tech Discussion
    Last Post: 08-25-2010, 07:34 AM
  5. AC Recharge Question
    By dmontgom in forum General Tech Discussion
    Last Post: 05-02-2009, 06:54 PM
