Thread: Diagnosing a/c system possible freon leak?
Results 1 to 8 of 8
  1. #1 Diagnosing a/c system possible freon leak?
    Sep 2015
    Lansing, Michigan
    02 gp gt 3.8l.
    Bought the car in 2015 and the ac never worked. The vents just blow hot air and the compressor clutch never engages. Upon pushing down on the shrader valve there is no hissing or indication of refrigerant in the system. Every once in a while the compressor pulley makes a scraping noise typical of these gm compressors because of the springs. I did apply 12 volts straight to the ac compressor and it kicks on with no odd noises while spinning.
    Auto zone here loans vacuum pumps and ac gauges. Should I first try vacuuming the system and see if it holds? What about uv dye and those harbor freight battery powered ac 'sniffers'?
  2. #2 Re: Diagnosing a/c system possible freon leak?
    St. Louis
    I'd try and vac it down and get a charge in it. Then throw some of the UV dye in as well. Not sure if you'd get the UV dye to show up with an empty system since there is no refrigerant to move it around.
    Never tried the Freon sniffers before. Usually my leaks show up with the dye.
  3. #3 Re: Diagnosing a/c system possible freon leak?
    Sep 2015
    Lansing, Michigan
    Well I vacuumed for 20 mins and it went to -27 psi. Shut the vacuum off. And it remained at like -27 psi for another 20 mins and didn't go anywhere.
    So I should maybe vacuum for maybe another 45 mins and let it sit for a hour or so
  4. #4 Re: Diagnosing a/c system possible freon leak?
    Sep 2015
    Lansing, Michigan
    Well I recharged the system and it's blowing very cold. I did put a bit of dye in the system also.
    Drove for an hour and so far it's blowing cold air good
  5. #5 Re: Diagnosing a/c system possible freon leak?
    St. Louis
    If it held vac for at least 20 min then it's probably a small leak. Mine held for 30min+ and eventually leaked down, but it took a while. If it gets hot again time to start looking for dye.
  6. #6 Re: Diagnosing a/c system possible freon leak?
    HUDSON
    Look at the bottom of the a/c compressor to see if it is wet with oil (might need a small mirror). If it is wet then the compressor shaft seal is leaking, like mine is. I have to add Freon if the car sits, but if I use everyday the leak is much slower.
  7. #7 Re: Diagnosing a/c system possible freon leak?
    Sep 2015
    Lansing, Michigan
    I'll have to check tomorrow. Today it's still blowing cold.
    If the shaft seal is leaking, will it be easy to see with the dye? Will I have to remove the pulley or anything to see?
  8. #8 Re: Diagnosing a/c system possible freon leak?
    St. Louis
    If you have the yellow glasses that come with most UV kits it'll be really obvious, trust me. Heck, even in dim light you may be able to see the green tint from the dye.
  1. Help with freon leak 99 GTP
    By hshift in forum General Tech Discussion
    Last Post: 08-13-2016, 02:48 PM
  2. freon leak on 99 grand prix se
    By chedder in forum Introductions/Noob Questions
    Last Post: 06-25-2012, 08:15 PM
  3. A/C Freon leak
    By BlackandSilverGTP in forum General Tech Discussion
    Last Post: 04-07-2010, 07:54 AM
  4. A/C Freon leak
    By lilnate7326 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 11:38 AM
  5. diagnosing fuel leak
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 03:27 AM
