Thread: E85 prices
Results 1 to 8 of 8
  1. #1 E85 prices
    Kemmerer, Wyoming
    I went and bought 30 gallons of E85 this morning. it cost 1.999 a gallon. I was hoping that since it went up .30 cents a gallon from last fall the ethanol content would be higher than it was last fall. still 70% ethanol.
    How much are you guys paying for E85? and what is the actual ethanol content?
    https://drive.google.com/file/d/0B6K...ew?usp=sharing
  2. #2 Re: E85 prices
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    $1.79 here in nc
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  3. #3 Re: E85 prices
    GXP Level Member
    Mar 2015
    Tomball
    $1.85
  4. #4 Re: E85 prices
    Kemmerer, Wyoming
    just tested a batch of E85, turns out it's E90, and is now 1.90.
  5. #5 Re: E85 prices
    Jul 2014
    Greenville SC
    Saw it for $1.82 earlier today
  6. #6 Re: E85 prices
    May 2016
    Burns City, Indiana
    Feel lucky the spec now for E85 is merely 51%. It USED to be minimum of E70. Now many of the refiner/blenders stuck with the E70 standard but most retailers found out that selling @E51 is E50 fails miserably. According to my chart if blended w/87 E70 can be from 95-100 octane but I'd still be conservative till you read how the engine likes it.
    A friend of mine built a fuel sensor gauge that hooks to flex fuel sensors, and will give temp and ethanol content. He has been working on a third reading based off of the combination of ambient, fuel temp and ethanol content.
    Good luck
  7. #7 Re: E85 prices
    Kemmerer, Wyoming
    I do feel very fortunate that the ethanol content is 90%. Overkill built an ethanol content that ends up costing like 250 does your friend use an auxiliary input to data log it on the hp tuner? I have the ethanol content kit and was going to install it on my 2008 GXP, just haven't got to it, but it would be interesting to have it on my 2001, would make it convenient to see what the ethanol content is without having to test it.
  8. #8 Re: E85 prices
    Nov 2011
    NY
    http://www.aviationfuel.org/faqs/alcohol_testing.asp
    Fill a clean container with gasoline drawn from the fuel system of the affected vehicle then fill another container with
    water. Only a small amount of fuel is needed to perform the test (5 ounces of each fluid).
    Slowly draw 3cc of water into the syringe. To remove air, draw at least 5cc of water, invert the syringe and
    squirt the water out until the top rim of the rubber plunger is at the 3cc mark.
    Slowly draw gasoline into the syringe up to the 12cc mark.
    Place your finger over the tip of the syringe, vigorously shake the syringe for a minute. Relieve built-up pressure by
    removing your finger.
    Place the syringe on a flat surface with the nozzle pointing up, allow the syringe to stand for one minute.
    If alcohol is present in the fuel, it will separate from the gasoline and dissolve in the water. This water/alcohol mixture will
    be in the lower part of the syringe. Record the reading at the boundary of the two liquids, refer to the table below to
    determine the percentage of alcohol in the fuel.
    Empty the syringe and rinse thoroughly with water, allow drying and apply a silicone lubricant to the rubber plunger before
    storing.
    Boundary Line % Alcohol Boundary Line % Alcohol
    9.0cc 0% 5.0cc 45%
    8.6cc 5% 4.5cc 55%
    8.1cc 10% 4.1cc 60%
    7.7cc 15% 3.6cc 65%
    7.2cc 20% 3.2cc 70%
    6.8cc 25% 2.7cc 75%
    6.3cc 30% 2.3cc 80%
    5.9cc 35% 1.8cc 85%
    5.4cc 40% 1.4cc 90%
    Or you could just use any container, use the same proportions and do the math...
    or or just get one of these, place inline with fuel rail, and whoola! Lol...
    http://www.zeitronix.com/Products/ECA/ECA2.shtml
  1. zzp low prices
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 07-20-2015, 09:30 PM
  2. GTP prices?
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 02-27-2012, 11:14 AM
  3. gas prices
    By gtcoup in forum Off Topic Discussion
    Last Post: 05-06-2011, 08:00 PM
  4. ZZP and there prices
    By MidnightBlue in forum The Rant Forum
    Last Post: 02-16-2011, 08:59 AM
  5. Gas Prices!!!
    By GeddyLee in forum The Rant Forum
    Last Post: 06-04-2009, 03:26 PM
