Thread: electrical problem maybe?
Results 1 to 6 of 6
GTP GRANDPRIX electrical problem maybe? 10-28-2012, 08:29 PM
Sushamouf Check fuses. Underhood by the... 10-28-2012, 08:36 PM
rperry435 Ignition switch? Sent from... 10-28-2012, 08:56 PM
joe0813 Re: electrical problem maybe? 10-29-2012, 08:07 PM
2003grandprixgt Re: electrical problem maybe? 06-24-2017, 11:04 PM
wowitsfast Re: electrical problem maybe? 06-24-2017, 11:12 PM
  1. #1 electrical problem maybe?
    Oct 2012
    MI
    my information center has stop working and my heat/AC keeps flashing off and on about every 10 seconds it just keeps doing it. when my information center went out my Heat and ac also went out at the same time im just trying to figure out whats going on can n e one help me plz thank you its a 98 gtp
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Check fuses. Underhood by the batt and in the pass glovebox.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    Ignition switch?
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  4. #4 Re: electrical problem maybe?
    GTP Level Member joe0813's Avatar
    Boston, MA
    if they flash on and off it wouldnt be a fuse.. if it was a fuse youd have zero volts and the display wont work.... Take the whole display out and check your power wire for a intermittent short to power
  5. #5 Re: electrical problem maybe?
    May 2016
    St. Louis
    My daughters 2003 GT is doing the same exact thing. What did you find caused your issue?
  6. #6 Re: electrical problem maybe?
    Oct 2014
    portland oregon
    none of these guys have been active is along time
  1. electrical problem
    By chris99gtp in forum General Tech Discussion
    Last Post: 09-03-2012, 05:32 PM
  2. Electrical problem?
    By lucyboop in forum General Grand Prix Discussion
    Last Post: 06-22-2012, 05:13 AM
  3. Possible Electrical problem?
    By KirkpatrickJTK in forum General Tech Discussion
    Last Post: 11-16-2011, 07:20 PM
  4. ac electrical problem
    By PrissiePantsGT in forum Audio, Security & Visual Electronics
    Last Post: 09-13-2010, 02:09 PM
  5. Electrical problem
    By jokyfo in forum General Tech Discussion
    Last Post: 08-31-2010, 08:27 AM
