Thread: Coolant leak
Results 1 to 12 of 12
  1. #1 Coolant leak
    SE Level Member GPmanter's Avatar
    Nov 2011
    Reynoldsburg, Oh
    My Dad has a 2006 Grand Prix base model that has a coolant leak on the passenger side. I noticed last week it was wet on the passenger side subframe but didn't leak when running... Until now.
    The car is dripping and puddling on the passenger side but can't really tell where it was from. Noticed the bottom of the block is wet with coolant but couldn't see where it's from.
    Any suggestions where to look?
  2. #2 Re: Coolant leak
    Aug 2011
    'Merica
    Could be the Water pump or the coolant elbows. The elbows are plastic and tend to get brittle with age. If that is the case, get some aluminum ones from your local auto parts store.
  3. #3 Re: Coolant leak
    Nov 2011
    Reynoldsburg, Oh
    Quote Originally Posted by Below Average Joe View Post
    Yeah the elbows failed last year on him as did the water pump. Found it was a reman unit which he now says was a mistake. Will have to take a look at it tomorrow when there is more light and it's cooled down. Hope it's just the pump.
  4. #4 Re: Coolant leak
    Timing cover gaskets like to leak on them too.
  5. #5 Re: Coolant leak
    Nov 2011
    Reynoldsburg, Oh
    There any particular way to tell if it is the timing chain cover? I tried to trace it when the engine was running and the car was on the ramps but couldn't see the point of leak. Just could see the coolant on the subframe and bottom of the block on the passenger side was wet with dripping coolant. The engine mount area in particular was also dripping.
  6. #6 Re: Coolant leak
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Coolant dye kit. Should make finding the leak much easier.
    Sent from my SM-G920P using Tapatalk
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  7. #7 Re: Coolant leak
    Nov 2011
    Reynoldsburg, Oh
    Quote Originally Posted by EJOUIE View Post
    Thanks for the suggestion. Since the belt is easy to remove I will pull it off bad well as the water pump pulley for a quick visual and do the dye test if I don't see anything
  8. #8 Re: Coolant leak
    Nov 2011
    Reynoldsburg, Oh
    the picture shows where the leak is. Not sure
  9. #9 Re: Coolant leak
    Nov 2011
    Reynoldsburg, Oh
    The more I look at it I think it is a leaking timing cover gasket.
  10. #10 Re: Coolant leak
    Nov 2011
    Reynoldsburg, Oh
    Found out it was the timing cover gasket. The water pump wasn't leaking at the moment but noticed the pulley has a little play in it as well. Sad since the one on the car was less than a year old. I also decided to replace the coolant elbows with aluminum elbows to be on the safe side since it was all apart anyway.
  11. #11 Re: Coolant leak
    Nov 2011
    Reynoldsburg, Oh
    pulled the cover off the engine and it had clearly been leaking for a long time. Above the water jacket was covered in crystallized coolant to the point it looked like one solid surface. I am degreasing the cover and will put it back on the engine. He thought he had serious engine problems because he would have to add antifreeze periodically but turns out it was just a leaky timing cover gasket. Add a brand new water pump and aluminum elbows and it'll be good to go for a while longer.
  12. #12 Re: Coolant leak
    GTP Level Member
    Oct 2014
    Been a bunch of these lately.
  1. Small coolant leak turned into a large coolant leak
    By DreamerGT in forum General Tech Discussion
    Last Post: 09-23-2016, 11:00 AM
  2. Coolant leak
    By Kellson in forum General Grand Prix Discussion
    Last Post: 02-20-2014, 10:44 AM
  3. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Coolant leak
    By john breit in forum General Tech Discussion
    Last Post: 02-12-2011, 05:12 PM
