Thread: Crank pulley bolt removal
Results 1 to 12 of 12
  1. #1 Crank pulley bolt removal
    SE Level Member GPmanter's Avatar
    Nov 2011
    Reynoldsburg, Oh
    I know it may sound like an idiot question but I'm at a loss. Trying to remove the crank pulley on my dads 06 Grand Prix and the bolt won't budge. Tried an impact but no luck. Any suggestions?
  2. #2 Re: Crank pulley bolt removal
    Stronger impact or use a breaker bar with a long pipe on it.
    You'll have to wedge a pry bar or something into the flex plate teeth to stop it from spinning.
  3. #3 Re: Crank pulley bolt removal
    St. Louis
    Not an idiot question, these things put up quite a fight. Lock the flexplate with a vicegrip and pull on the crank bolt with a 4 foot breaker bar. Should do the trick.
    Once you get the bolt out be sure you have the proper bolts/remover for the balancer so you don't damage it. Also, once you go to reinstall the balancer be sure you line up the woodruff key and shove the balancer on by hand to be sure it's correct before you run the bolt back in or you could screw up the key slot in the crankshaft. It happens more than you would think so just a heads up.
  4. #4 Re: Crank pulley bolt removal
    breaker bar and the starter, google redneck crank bolt removal.
  5. #5 Re: Crank pulley bolt removal
    Nov 2011
    Reynoldsburg, Oh
    I thought of trying that but since the car will continue to crank for so many seconds after releasing the key I wasn't too sure about that method
  6. #6 Re: Crank pulley bolt removal
    GXP Level Member
    Mar 2015
    Tomball
    It'll work I have done it on my 05', just turn the key off after it pops loose.
    Jeff
  7. #7 Re: Crank pulley bolt removal
    Nov 2011
    Reynoldsburg, Oh
    Thanks for the suggestion guys. I bought a new impact and didn't make a lick of difference so I used the redneck method and stopped when I heard it snap loose. Now to buy the bolts for the puller. I had some at one time but my garage is a nightmare. They are probably hiding with my 13mm deepwell. I will go to lowes and get the 1/4" bolts to remove the pulley. Then I can finish this blasted timing cover
  8. #8 Re: Crank pulley bolt removal
    PA
    Quote Originally Posted by GPmanter View Post
    Also,
    Make sure to use hardened bolts. Grade 8 if possible. Grand 5 is better than nothing, but can still break.
    2001 GSE
  9. #9 Re: Crank pulley bolt removal
    Nov 2011
    Reynoldsburg, Oh
    Quote Originally Posted by Zef_66 View Post
    Also,
    Yup that's what I was thinking as well.
  10. #10 Re: Crank pulley bolt removal
    GXP Level Member
    Mar 2015
    Tomball
    They are usually 1/4-28 fine thread.
  11. #11 Re: Crank pulley bolt removal
    fyi, they are not 1/4 inch thread bolts. its metric, and you dont need hardened bolts. bolts are listed here, get some washer cause the heads will be to small and can pull through the puller http://www.grandprixforums.net/threa...a-crank-sensor
  12. #12 Re: Crank pulley bolt removal
    Nov 2011
    Reynoldsburg, Oh
    Thanks for everyone's help! from breaking the bolt loose with the engine, to the tutorial that showed the crank pulley removal I've got the pulley off the car. I may not have my Grand Prix any longer but am glad I am able to get help when I work on my Dad's car.
  1. How many times can a crank bolt be re used?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2012, 06:26 AM
  2. 24 mm bolt on crank?
    By legend in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2012, 05:01 AM
  3. Crank Bolt Will Not Come off
    By BoilerTom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2012, 08:03 AM
  4. HELP! Can't remove crank pulley bolt!!!
    By Billy Low in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:06 PM
  5. Pulley bolt removal
    By Zinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2009, 07:54 PM
