Thread: Locating Coolant Leak
Results 1 to 20 of 21
  1. #1 Re: Locating Coolant Leak
    GTP Level Member
    Oct 2014
    Check the timing cover gasket and the heater hose o-rings in the alternator bracket. I have had both this leak on me but could see both when the system pressured up.
  2. #2 Re: Locating Coolant Leak
    Mar 2017
    WI
    Quote Originally Posted by markpa View Post
    The heater hose o-ring area is dry, but I willsee if I can get a mirror back there to check it out.
  3. #3 Re: Locating Coolant Leak
    Jun 2013
    Glendale, AZ
    I've heard the only other things that have coolant back there are a knock sensor and frost plugs, I really hope it's neither of those. A shop replaced the area where the heater hoses attach to the tensioner assembly. I felt all along there but it's dry. My leak is further back it seems as it doesn't get on my oil filter, although my front end was on jack stands at the time of the pressure test.
  1. Small coolant leak turned into a large coolant leak
    By DreamerGT in forum General Tech Discussion
    Last Post: 09-23-2016, 11:00 AM
  2. Coolant Leak
    By blackthunder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-31-2013, 09:56 PM
  3. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Help with coolant leak
    By eagleeyes9 in forum General Tech Discussion
    Last Post: 12-09-2008, 04:45 PM
