Thread: Passenger CV Axle Help
Results 1 to 17 of 17
  1. #1 Passenger CV Axle Help
    Washington
    Ok, after extensive searching, I came up with this thread:
    http://www.grandprixforums.net/showthread.php?t=61218
    So that IS the axle I have in hand, but this is what my passenger side looks like. 20160913_070829.jpg
    So, what the heck is sticking out of the differential? And how do I remove it?
    99 grand prix 3.8 na
    All stock, axles replaced 4 years ago without issue.
    Thanks,
    Jon
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  2. #2 Re: Passenger CV Axle Help
    HUDSON
    "So, what the heck is sticking out of the differential? And how do I remove it?"
    Answer: axle shaft, no need to remove it.
    The clip on the end of the axle looks ok, but the seal looks like it has been leaking, best to get a new seal installed before installing the cv/axle.
  3. #3 Re: Passenger CV Axle Help
    Washington
    Hey Quicksilver,
    I'm confused. Looking at the axle, from the other post, it is male on both ends. Every parts store website I've checked shows that the passenger side CV axle is male on both ends. Driver side is male at the wheel, female at the trans. Are you sure that shaft is supposed to be there? Is there a coupler or something that goes between the Trans and axle on the passenger side?
    Thanks,
    Jon
  4. #4 Re: Passenger CV Axle Help
    Can you push the shaft back in?
    There is a long shaft that goes through the whole tranmission and can pop out when changing axles. The other end will go into the drivers side axle while the part sticking out should be inside the diff in the transmission itself.
  5. #5 Re: Passenger CV Axle Help
    Washington
    Hmm, ok. I'll pull the driver's side. If the shaft did slide, then there shouldn't be a stub sticking out that side.
    I'll post back tomorrow after pulling the driver's side.
  6. #6 Re: Passenger CV Axle Help
    HUDSON
    Ahhh yes, I see.
    Is your transmission original to the car?
  7. #7 Re: Passenger CV Axle Help
    Washington
    Yes, the trans is original. The only work done had been to replace both CV axles and the wheel hubs. Did that about 4-5 years ago. Simple to do if I recall correctly. I did the trans seals at the same time.
  8. #8 Re: Passenger CV Axle Help
    I'm thinking there is a much bigger issue here. That looks like the end of the driveshaft that should be internal to the transmission. You should never see that on the passenger side as you are. The only way I believe that can happen would be for the diff pin to be destroyed and the driveshaft would have separated from the drivers side cv axle as well.
    Head over to the driverside and see if the cv appears to be attached to the trans.
  9. #9 Re: Passenger CV Axle Help
    HUDSON
    Did you stick a broken axle shaft in there?
  10. #10 Re: Passenger CV Axle Help
    Washington
    Hi everyone,
    Sorry, had to work late yesterday couldn't get to it till this morning.
    That is not a broken axle - the old one slipped right out.
    Took off the driver's side down to the half shaft. I can't seem to get it out. Like the c-clip is locked in hard. This would suggest that the output shaft has NOT slid towards the passenger side.
    I'm going to see if the parts store has the tool to remove the driver's CV. To confirm that there is a male spline on the driver's side.
    Any thoughts?
  11. #11 Re: Passenger CV Axle Help
    HUDSON
    The drivers side axle cannot slide toward the passenger side due to the differential pinion shaft in the way, also there is not enough splines on the end to allow movement that far anyway.
  12. #12 Re: Passenger CV Axle Help
    Washington
    Ok, that makes me feel 'a little' better.
    Finally got the driver's side pulled. As suspected, it looks like I thought it would.
    So, back to the original question.
    What is sticking out the passenger side and how do I remove it.
    Also, at this point, I'm going to do my front struts. Any advice on getting loaded vs. bare struts and swapping the springs?
  13. #13 Re: Passenger CV Axle Help
    Washington
    Any thoughts on this?
    Should I try to yank out the shaft on the passenger side?
    Thanks,
    Jon
  14. #14 Re: Passenger CV Axle Help
    HUDSON
    Pull that part sticking out, OUT! (if you can)
  15. #15 Re: Passenger CV Axle Help
    Washington
    Woot! Woot!
    Finally got that thing out!
    We had freezing weather and snow last week, so it wasn't until today (in the rain) I could work on it.
    Took about half an hour with vise grips and a slide hammer but it finally popped out.
    Looks like it's a little stubby shaft, a shaft "coupler" of sorts.
    Here it is:
  16. #16 Re: Passenger CV Axle Help
    Washington
    So now that that is done, what does everyone think about loaded vs bare front struts?
  17. #17 Re: Passenger CV Axle Help
    HUDSON
    WOW, that little shaft is bizzzare! It is either custom made, or very rare!
  1. Can't remove passenger axle
    By vertebrate in forum General Tech Discussion
    Last Post: 08-28-2012, 02:01 PM
  2. passenger side axle seal
    By hitnf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2012, 11:28 PM
  3. Passenger side (right) axle seal
    By SJAndrew in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-05-2012, 01:53 PM
  4. Axle passenger side.
    By VGPGT in forum General Tech Discussion
    Last Post: 01-31-2012, 09:44 AM
  5. Will a passenger cv axle from gtp work on a gt
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 12-30-2010, 10:48 PM
