View Poll Results: Best solution for radiator leak
Voters
0. You may not vote on this poll
  • Looks like end tank leak; Get a new Radiator
    0 0%
  • Looks like Petcock leak; Get a new Petcock
    0 0%
Thread: Radiator Coolant Leak near Petcock
Results 1 to 3 of 3
  1. #1 Radiator Coolant Leak near Petcock
    GTP Level Member buickman104's Avatar
    NYC
    Got the low coolant light. Noticed a wet spot near the petcock. Hooked up my coolant leak tester and pressurized the system to 15 PSI. Recorded this video while the system was pressurized.
    https://www.dropbox.com/s/hunvkhdchq...0Leak.mp4?dl=0
    For people with similar experiences does it seem like the leak could be resolved with just a new Petcock? or does it seem like I need a new radiator? It is hard to tell if it is leaking from the end tank or just the petcock.It is not audible in the video but there is a strong hissing sound when pressurized.
    Radiator looks original and car has 217,000 Miles.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Radiator Coolant Leak near Petcock
    try the blind camera man trick lol stick your phone down in front of that area and see where its bubbling from.
    its wet there, but the tank could also be cracked.
  3. #3 Re: Radiator Coolant Leak near Petcock
    NYC
    Good point! I'll give that a shot!
  1. Small coolant leak turned into a large coolant leak
    By DreamerGT in forum General Tech Discussion
    Last Post: 09-23-2016, 11:00 AM
  2. 2004 GT1 Radiator petcock location
    By swebber in forum Introductions/Noob Questions
    Last Post: 11-11-2013, 01:21 PM
  3. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  4. Small coolant leak. Radiator drain plug
    By eric37428 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-23-2013, 07:42 PM
  5. coolant leak--petcock?
    By PrixAngel in forum General Tech Discussion
    Last Post: 03-26-2011, 01:08 PM
