sounds like the fuse blew for the obd2 port, check the fuse for the power port. or see if it works, if its not working then the fuse blew. im guessing the check engine light is on? and he cant scan the car for codes?
Well, the cig lighter works fine as does the port on the side of the console. We have a handheld OBD scanner and I plugged it in and it instantly says "no codes". When I plug it into our Jeep it goes through the scanning process first. Does this sound like there is an issue with the OBD port still. If there is a problem with that port could the cig lighter and power port still work fine? Oh, and no, there is no check engine light on at all. That is what is weird!
