Thread: Needs some help with finding the ECM brain....
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21 Re: Needs some help with finding the ECM brain....
    Dec 2016
    Alabama
    Looks like that is our next task! Thanks guys. I really hope this is the problem. Thank you for all of your help and assistance, you are awesome!
  2. #22 Re: Needs some help with finding the ECM brain....
    good luck, hoping for the simple fix.
    oh, its held on with two small bolts, but they are not bolts, you need whats called security torx bits to get them out. or, take a hacksaw and cut a slot across the head and use a flat head screw driver. how i rigged mine, i used a thin disc on a grinder tho.
  3. #23 Re: Needs some help with finding the ECM brain....
    The tap test usually works when it's running good btw. If you tap and it faulters.. you know
  1. Ok this is boggling my brain now
    By Black97GTP2dr in forum General Tech Discussion
    Last Post: 08-18-2012, 01:14 PM
  2. My car has brain farts
    By bankai in forum Introductions/Noob Questions
    Last Post: 06-15-2010, 11:03 PM
  3. Time to pick your brain
    By selliott in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-10-2010, 07:32 PM
  4. Brain fart ?
    By Nickell in forum Off Topic Discussion
    Last Post: 02-06-2010, 07:46 AM
  5. My Brain hurts
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 09-03-2008, 12:07 PM
