Thread: Cam install, so many misfires TCC wont lock
Page 2 of 9 FirstFirst 1234 ... LastLast
Results 21 to 40 of 163
  1. #21 Re: Getting ready for cam, need suggestions
    Quote Originally Posted by ItHurtz View Post
    s3x that sht
    Fixed
  2. #22 Re: Getting ready for cam, need suggestions
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    So I may or may not need it machined? How long will a single last with an xp and 90s? I figured do 130s so I could shift up to 6200
    02 GTP - Cartuning Turbo Kit VS67 3" DP, 80#INJ, N*,LQ4 MAF, Custom Cam, Roller Rockers, 130#, P&P Heads, Meth, AL103's, Corn fed, 522WHP on a mustang dyno, HP Tuners by me.
  3. #23 Re: Getting ready for cam, need suggestions
    Kemmerer, Wyoming
    I shifted mine at 6200 with 90's and a stock timing chain. it will last plenty long enough.
  4. #24 Re: Getting ready for cam, need suggestions
    I always hear mixed things about what valve springs will work and what ones do not with said cams, I've had people tell me they ran 90s on a S3x Intense cam for years with no issues, and others tell me that 90s will never last and you need at least 130s for something like that. But 130s do seem a tad overkill for an XP cam, most guys run 105s iirc.
  5. #25 Re: Getting ready for cam, need suggestions
    Nebraska
    So single roller it is, I still need modified retainers With both 90 and 105 correct?
  6. #26 Re: Getting ready for cam, need suggestions
    Kemmerer, Wyoming
    Correct
  7. #27 Re: Getting ready for cam, need suggestions
    Nebraska
    So my last question which sounds like it'll be an opinion more than a fact but 105 or 90s?
  8. #28 Re: Getting ready for cam, need suggestions
    Kemmerer, Wyoming
    90's. It's more than opinion, GM put a ton of research and development into those springs and the have a huge success rate
  9. #29 Re: Getting ready for cam, need suggestions
    Quote Originally Posted by SgtMarshal View Post
    Aren't the 90s from an LS6?
  10. #30 Re: Getting ready for cam, need suggestions
    Kemmerer, Wyoming
    GM uses them in a lot of different vehicles, the LS6 is one
  11. #31 Re: Getting ready for cam, need suggestions
    Quincy, Mass
    I personally like 105s with cams, they work for the vs, xp, and s1x, going bigger and you'll want 130s or 150s depending on the cam. Nothing wrong with the 90s it's just a personal preference.
    I had a machined gear on my double roller and ran 2 gaskets and it still rubbed on one of my covers with the turbo cam. Now this may have been installer error since it didn't happen with my xp or is3 cam setups, same double roller was used with all my builds. That being said if I were to do it again I would have it machined, use a machined oil pump cover and use the thicker gasket just to be safe. Is it needed, no, but I'd rather have the extra room.
    Don't forget the oil high pressure kit if you don't already have one.
    No more GP 04 Impala SS Indy:
  12. #32 Re: Getting ready for cam, need suggestions
    Antioch, IL
    Quote Originally Posted by Swiggles View Post
    aka.a.washer.as.a.spacer...my.space.bar.stopped.wo rking.wtf....
    2009 Challenger SRT8
    Expert at being gay.
  13. #33 Re: Getting ready for cam, need suggestions
    Quincy, Mass
    Lol yes a washer but I couldn't remember if the thinkness mattered.
  14. #34 Re: Getting ready for cam, need suggestions
    Antioch, IL
    another thread someone said 1/4"
  15. #35 Re: Getting ready for cam, need suggestions
    It's not your space bar mine does it too.
    Sent from a galaxy far far away.
  16. #36 Re: Getting ready for cam, need suggestions
    hangover park IL
    OEM T chain with 27k, upgraded to VS/105's. 46k later the tensioner and chain went out taking out 8 valves and 4 of 6 pistons, 300 mile tow bill/etc that would have paid for at least 3 double roller sets.
    saving $ never really saves you $
    ~James~ Psychotic Gearhead
  17. #37 Re: Getting ready for cam, need suggestions
    Nebraska
    Pulling the engine right now all my parts are here, should I leave the balance shaft and gear on? I've read the forum and there is a lot of controversy just your opinions.
  18. #38 Re: Getting ready for cam, need suggestions
    Quincy, Mass
    If you're using the stock timing chain the yes leave it on. If you're using the rollmaster double then you have to remove balance shaft gear, you can leave the shaft in though it hurts nothing to leave it in.
  19. #39 Re: Getting ready for cam, need suggestions
    May 2008
    Schuyler, NE
    If you are running an xp, you should be using a 130# spring.
  20. #40 Re: Getting ready for cam, need suggestions
    Nebraska
    Okay balance shaft stays in.
    What's your beef with the 90s? I know they have a high ramp rate but other than that they seem pretty solid.
  1. Getting car ready for the track... Any suggestions?
    By GTPMidknight in forum Track Sessions and Kills
    Last Post: 01-31-2015, 10:44 AM
  2. About ready to cry..PLEASE help
    By TJs97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2013, 09:13 PM
  3. I'm ready to have some fun with a GP
    By Chmanzi in forum Introductions/Noob Questions
    Last Post: 11-25-2009, 11:18 PM
  4. Hey all! Get ready!!
    By 69Fiat in forum Introductions/Noob Questions
    Last Post: 08-09-2009, 11:01 PM
  5. Getting Ready. Any Last Suggestions???
    By kingbrentdwyer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2009, 01:09 PM
cam
