Thread: One door lock does not respond to key fob.
Results 1 to 7 of 7
  1. #1 One door lock does not respond to key fob.
    Aug 2016
    S.F. Bay Area (east bay), California
    Any idea what causes ONE door lock to no longer respond to the key fob? The driver's side rear door on my 2001 GP GT just does nothing in respone to the key fob, neither locking nor unlocking. It can of course, be operated manually. Is there a typical way these things fail? Anything I should look for?
  2. #2 Re: One door lock does not respond to key fob.
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    I'd check the connections to the BCM, and the harness going into the door, sounds like it's a dead wire somewhere between those two.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: One door lock does not respond to key fob.
    GTP Level Member
    Oct 2014
    I think the actuators go bad quite often. Does it work with the switch in the drivers door?
  4. #4 Re: One door lock does not respond to key fob.
    Nov 2012
    Madison
    can you hear the actuator?
    my 04 rear passenger starting on and off until it wouldn't move.
    I could hear mine so I took the door panel off and shot it with silicone spray + all the parts. I worked it manually until smooth.
    I think the rod had become misaligned
  5. #5 Re: One door lock does not respond to key fob.
    Aug 2016
    Quote Originally Posted by markpa View Post
    Dang, that's a good question. I will check this.
  6. #6 Re: One door lock does not respond to key fob.
    Aug 2016
    Update: When it doesn't work with the key fob, it also does not work from the switch in the driver's door. However, randomly yesterday it started working with both the key fob and the driver's door switch, then a while later it no longer worked with either. When it works, you can hear the actuator when you're standing next to that door. When it doesn't work, you don't hear it. So. . . it's intermittent!
    I'll probably open up the door and check the wiring, and spray some silicone lube on the actuator in case it's sticky.
  7. #7 Re: One door lock does not respond to key fob.
    in the wiring accordion door to car body. inside there or at the edge you might have a pinched wired.
  1. 99 GPGT Passenger inside door lock and key lock not working at all.
    By 71gs3504sp in forum General Tech Discussion
    Last Post: 07-26-2016, 04:55 PM
  2. Door Lock Actuator Replace - Now doors won't electronically lock
    By rmortime in forum General Tech Discussion
    Last Post: 11-17-2012, 12:37 AM
  3. 1997 GTP Passenger Side Door Wont Respond to Lock/Unlock
    By Calikid219 in forum General Grand Prix Discussion
    Last Post: 05-21-2012, 09:57 PM
  4. door lock help
    By dudleyc05 in forum General Tech Discussion
    Last Post: 01-29-2011, 05:29 PM
  5. remote door lock horn only when lock ?
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 12-10-2008, 09:05 PM
