Thread: 1997 GTP Passenger Side Door Wont Respond to Lock/Unlock
Results 1 to 7 of 7
  1. #1 1997 GTP Passenger Side Door Wont Respond to Lock/Unlock
    May 2012
    Tracy, California
    For as long as I can remember, the passenger side door on my 1997 Pontiac Grand Prix GTP wont unlock or lock when i hit the button on either control panel or the buttons on my key. I think its time to fix that but i dont really know whats causing it or how to fix it. Any help?
  2. #2 Re: 1997 GTP Passenger Side Door Wont Respond to Lock/Unlock
    Jan 2012
    Philadelphia
    you have to hit the unlock button twice
    but not sue it might be broke if it doesn't lock
  3. #3 Re: 1997 GTP Passenger Side Door Wont Respond to Lock/Unlock
    May 2012
    Tracy, California
    Quote Originally Posted by gtpeddie View Post
    Well its most definitely broke. Im just wondering whats broke and how to fix it.
  4. #4 Re: 1997 GTP Passenger Side Door Wont Respond to Lock/Unlock
    if you take the inside door skin off, and look up where the door handle is there should be a lock actuator, with a plug and a metal rod to work the locks with, make sure its still plugged in, or for bad connections at the plug.
    i have a rear one that went bad, all it did was make noise and not work. so i un plugged it. back door pass side, it dont bother me. front door would bother me. lol
  5. #5 Re: 1997 GTP Passenger Side Door Wont Respond to Lock/Unlock
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    Does the actual physical switch work? On my '98 both doors got to the point where you couldn't even move the switch any more. I popped the panels off, lubed the locks and called it a day.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  6. #6 Re: 1997 GTP Passenger Side Door Wont Respond to Lock/Unlock
    Few different possibilities here.
    Could be the drivers switch
    Could be the passenger switch
    Could be broken wires in the boot from the body to the door.
    I'd check and see if there's any power going to it and if the passenger side works.
  7. #7 Re: 1997 GTP Passenger Side Door Wont Respond to Lock/Unlock
    May 2012
    Tracy, California
    Well its definitely broke on the inside. Im thinking the Lock Actuator. Ill be taking my door apart soon..
  1. my passenger door wont unlock! Help!
    By Kelsey22 in forum General Tech Discussion
    Last Post: 10-05-2010, 02:50 AM
  2. 2006 Pontiac Grand Prix Driver door lock doesn't unlock
    By PianoMan99 in forum General Tech Discussion
    Last Post: 09-23-2009, 06:22 AM
  3. Passenger side door wont open
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-05-2009, 01:08 PM
  4. Trunk Switch/ Door Unlock and Lock
    By mainecrab in forum General Tech Discussion
    Last Post: 06-02-2008, 08:58 PM
