Thread: Can someone confirm info on a new cat?
Results 1 to 12 of 12
hockeybawler Can someone confirm info on a... 11-19-2016, 12:31 PM
Explicit_Spade Re: Can someone confirm info... 11-19-2016, 12:40 PM
hockeybawler Re: Can someone confirm info... 11-19-2016, 03:27 PM
Explicit_Spade Re: Can someone confirm info... 11-19-2016, 03:31 PM
hockeybawler Re: Can someone confirm info... 11-19-2016, 08:51 PM
REDCRAPGP Re: Can someone confirm info... 11-19-2016, 11:35 PM
Fivefingerdeathpunch Re: Can someone confirm info... 11-19-2016, 11:35 PM
hockeybawler Re: Can someone confirm info... 11-21-2016, 03:01 AM
willie14 Re: Can someone confirm info... 11-21-2016, 07:29 AM
hockeybawler Re: Can someone confirm info... 11-21-2016, 12:53 PM
hockeybawler Re: Can someone confirm info... 11-21-2016, 05:24 PM
willie14 Re: Can someone confirm info... 11-23-2016, 09:25 AM
  1. #1 Can someone confirm info on a new cat?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    My cat has gone bad on my 04 grand prix. From what I have read, I can get away with a 3" 400 cell cat from zzp and most likely not throw a code. Can anyone confirm that I have understood this correctly?
    Car is 04, topswapped, speeddaddy headers with new flexpipe, borla mufflers, and zzp tune. Thanks for the help in advance.
  2. #2 Re: Can someone confirm info on a new cat?
    Omaha, NE
    When you got the PCM did you choose either option that removed P0420 under the option 4 drop down?
  3. #3 Re: Can someone confirm info on a new cat?
    Oct 2011
    huntley
    I dont believe I did
  4. #4 Re: Can someone confirm info on a new cat?
    Omaha, NE
    You'll probably set off that code with a high flow cat. You can go to any auto parts store and pick up a spark plug anti fouler to place between the o2 sensor and the bung to resolve the issue. It's a couple dollar fix that seems to be pretty successful.
    Sent from my iPhone using Tapatalk Pro
  5. #5 Re: Can someone confirm info on a new cat?
    Oct 2011
    huntley
    What would you go with if you were in my position? Just a regular store bought one or a high flow cat? Also, is 3" correct or should I go 2.5"?
  6. #6 Re: Can someone confirm info on a new cat?
    If you have headers then you'll need a 3" cat. Personally I'd either run catless or replace with a high flow cat and have the codes deleted either way
    04 Comp G.
  7. #7 Re: Can someone confirm info on a new cat?
    I don't recall the part number off hand and I'm sure it's changed by now but magnaflow does sell a higher end cat converter that works far better than the high flow cats.
    I think they still might call it a high flow converter but it is double the price of the cheaper $50 dollar cats that you can just toss in there.
  8. #8 Re: Can someone confirm info on a new cat?
    Oct 2011
    huntley
    Will this one work? It doesnt need to be the best, just needs to get me by for the next year or two that I have the car. Thanks guys
    http://www.autozone.com/exhaust/cata...ter/34059_0_0/
  9. #9 Re: Can someone confirm info on a new cat?
    GT Level Member willie14's Avatar
    Jun 2016
    westland mi
    So what did u do with the speed daddy headers? U had a new flex welded in and then cut a section out to have a catwelded in and its bad already? How long have you had I like that?
    98 Grand prix SE to GTP conversion( in works). Full body conversion in works, drilled n slotted rotors, ceramics, all new suspension, custom CAI, NGK wires/Vpower plugs, SD headers, 180 Tstat, AND A WHOLE BUNCH OF PAINT BABY!! Tuned by E&J performance.
  10. #10 Re: Can someone confirm info on a new cat?
    Oct 2011
    huntley
    With the headers I had the flex cut out and a new one welded in since mine leaked from there just like others who have speed daddy's. I havent done anything with the cat, this is still my stock cat and I have had this combo now for about 4ish years.
  11. #11 Re: Can someone confirm info on a new cat?
    Oct 2011
    huntley
    So would the one I posted be a decent high flow cat to get me two years of time hopefully?
  12. #12 Re: Can someone confirm info on a new cat?
    Jun 2016
    westland mi
    I'm still runnin my SD headers with no leaks yet, SD flex and only used bandclamps on the 3 in DP the rest has just better U bolt style clamps..no rtv on nothing my slip joints were super tight so I didn't see the need to use it
  1. Confirm what all has been done to my car, help solve the mysteries!
    By dblackston in forum General Grand Prix Discussion
    Last Post: 11-30-2016, 02:26 PM
  2. Need to confirm trans issues rather than sensors.
    By fastline in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2015, 04:16 PM
  3. Help Confirm Diagnosis?
    By TuKoolGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2014, 01:36 PM
  4. How to confirm the car is not a 04 Comp G?
    By rizer in forum General Grand Prix Discussion
    Last Post: 12-04-2012, 03:27 AM
  5. Confirm my knocking
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 08-08-2012, 06:08 AM
