Thread: Throttle body bolt snapped off - cant find replacement
Results 1 to 13 of 13
  1. #1 Throttle body bolt snapped off - cant find replacement
    Donating Users
    Texas
    2004 GT
    Evidently my torque wrench isn't sensitive at <10ft/lbs and I wasn't paying attention, doing three things at once, and I snapped one of the upper two bolts right off. It's the one that screws into the plenum, top right if facing the the intake. I was able to get it out of the plenum clean, threads intact, now need a new screw for it.
    I've searched everywhere online and can't find a replacement screw/bolt that isn't included in a whole new throttle body. Can anyone point me in the right direction? Much appreciated.
  2. #2 Re: Throttle body bolt snapped off - cant find replacement
    Buffalo
    Have you tried taking a bolt with you to the hardware store and match it up?
  3. #3 Re: Throttle body bolt snapped off - cant find replacement
    Donating Users
    Texas
    I haven't. This happened an hour ago. The one that snapped seems soft and it screws through a plastic insert in the throttle body itself - would those things matter in matching a replacement? Anything else to keep in mind from hardware store?
  4. #4 Re: Throttle body bolt snapped off - cant find replacement
    Torque wrench?
    What is that?
  5. #5 Re: Throttle body bolt snapped off - cant find replacement
    Buffalo
    As long as the thread pitch and length are correct - I wouldn't be worried. Then if it bothers you - get to a junkyard later on and swap it out
    if you need to drive the car , you can goop the gasket and install a bolt top left bottom right and it should hold over to get you to a store.
    \_(ツ)_/¯
  6. #6 Re: Throttle body bolt snapped off - cant find replacement
    Topeka, KS
    Zzp sells those bolts if you want exactly the same
    Sent from my VS990 using Tapatalk
  7. #7 Re: Throttle body bolt snapped off - cant find replacement
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    You need a 1/4" drive torque wrench that measures in-lbs. So instead of trying to measure 10 ft lbs, you set for 120 in-lbs.
    Regarding the bolt, if the other one is the same, take it to the hardware store, or Fastenal if you have one nearby, and you are matching 3 things: 1. Length of the bolt, 2. Thread pitch, and 3. diameter. Head style is less important (phillips, hex, torx, etc.) as long as the the mating surface is the same size or close.
    IIRC, the studs on my 02 TB are M4 x 1.0 which means the bolt is 4mm in diameter and there is one thread per mm.
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  8. #8 Re: Throttle body bolt snapped off - cant find replacement
    Quincy, Mass
    And they only need to be like 2 inches long
    No more GP 04 Impala SS Indy:
  9. #9 Re: Throttle body bolt snapped off - cant find replacement
    Donating Users
    Texas
    Got it all put back together. An M6 60mm 1.0 did the trick. I'll keep an eye on it, but appears a perfect fit. Thanks y'all.
  10. #10 Re: Throttle body bolt snapped off - cant find replacement
    Dec 2008
    ****'s Creek
    60mm divided by 25.4 mms per inch = 2.36". Pretty close swiggles.
  11. #11 Re: Throttle body bolt snapped off - cant find replacement
    Quincy, Mass
    Quote Originally Posted by Burbman View Post
    I used the word "like" lol
  12. #12 Re: Throttle body bolt snapped off - cant find replacement
    Dec 2008
    ****'s Creek
    I know, I was saying you were pretty close going from memory. Wasn't meant to be a dig. maybe I should have used a smiley
  13. #13 Re: Throttle body bolt snapped off - cant find replacement
    Quincy, Mass
    Lol
  1. bolt on dbc throttle body for l26 intake manifold
    By randybill in forum General Tech Discussion
    Last Post: 09-15-2014, 09:59 AM
  2. Throttle body bolt snapped off
    By Dailordasailor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2012, 02:01 AM
  3. Throttle Body Replacement
    By Willywalk1128 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-02-2012, 02:20 PM
  4. Throttle body bolts snapped please help!!
    By mcsddd in forum General Tech Discussion
    Last Post: 06-18-2012, 07:16 AM
  5. Broken throttle body bolt, help!
    By 04gtgp in forum 04+ Specifics
    Last Post: 10-29-2011, 05:03 PM
