Thread: Throttle body bolt snapped off
Results 1 to 10 of 10
  1. #1 Throttle body bolt snapped off
    Sep 2012
    Watkins Glen, NY
    The car had a spacer in it and when removed spacer I put new grade 8 bolts in. One snapped off that was closest to the firewall on bottom of throttle body. Tried to EZ out it, wouldn't work. Tried to drill and tap it and appears I messed it up because couldn't get heli coil to thread in great... My question is, how deep can I drill it safely? It seems unlikely but can I drill straight through? Any one measure the depth often hole?
    worst comes to worst do I pull supercharge and have a shop tap it? Is pulling it a big pain? Just need new gaskets when put it back in?
    any help appreciated!
  2. #2 Re: Throttle body bolt snapped off
    Minnesota
    Did it snap off flush with the supercharger? Or can you take the rest of teh bolts off, remove the throttle body then use some vice grips to take it out?
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  3. #3 Re: Throttle body bolt snapped off
    Sep 2012
    Watkins Glen, NY
    Already tried to drill it out and heli coil after EZ out wouldn't work. So now in position where retap dosnt look to amazing
  4. #4 Re: Throttle body bolt snapped off
    GTP Level Member joe0813's Avatar
    Boston, MA
    so its flush with the supercharger now? yikes... dumb question but are you using the right drill buts to drill through metal?
  5. #5 Re: Throttle body bolt snapped off
    Sep 2012
    Watkins Glen, NY
    I drilled it out and put a heli coil in... But I didn't know how deep I could safely go so I didn't get as much thread value as I could. I'd love to be able to drill straight through and put nut on back but I'm doubting that's possible. Has anyone ever measured how deep the "hole" is for that bolt?
  6. #6 Re: Throttle body bolt snapped off
    Boston, MA
    take out one of the other bolts and stick a tooth pick in it.. mark it then measure the tooth pick where you marked it... that way you know how deep you need to drill
  7. #7 Re: Throttle body bolt snapped off
    Sep 2012
    Watkins Glen, NY
    Is both bottom bolts the same length? The upper one is straight through so didn't know if bottom two was same
  8. #8 Re: Throttle body bolt snapped off
    All three of the studs are the same length. I think it's around 1/2".
    Wondering why you were using a grade 8 bolt on a TB and how much force it took to break that. That's a lot of pressure.
  9. #9 Re: Throttle body bolt snapped off
    Sep 2012
    Watkins Glen, NY
    The scary thing is I barely put any pressure on them... In no way should it have snapped even being the cheapest bolt made.... As for grade 8 I buy them for anything car related even if not really a concern
  10. #10 Re: Throttle body bolt snapped off
    SE Level Member sco77's Avatar
    MD
    This is why you don't use grade 8s on parts that don't need them. But I'm really surprised you broke a grade 8 bolt before stripping aluminum threads, the torque is only suppose to be like 7-11 ftlb there.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  1. Looking for F-body Banjo Bolt source
    By buickman104 in forum Brakes/Suspension/Chassis
    Last Post: 06-18-2015, 03:44 PM
  2. Throttle body bolts snapped please help!!
    By mcsddd in forum General Tech Discussion
    Last Post: 06-18-2012, 07:16 AM
  3. Snapped Bolt
    By USF3983 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2012, 04:36 PM
  4. Broken throttle body bolt, help!
    By 04gtgp in forum 04+ Specifics
    Last Post: 10-29-2011, 05:03 PM
