Thread: Gasket replacement for Stock Manifold to 2.5" ZZP Downpipe
Results 1 to 16 of 16
  1. #1 Re: Gasket replacement for Stock Manifold to 2.5" ZZP Downpipe
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    sea foam your engine, then watch for the smoke to come out where its leaking from, some of these cars crack the rear manifold.
    no need to undo the down pipe at all. just the manifold off the head. take the two dog bones off so you can push and or pull on the engine to move it as needed.
    The engine has no mods except for HV3. The exhaust is all stock except for the downpipe, which is a ZZP stainless. On other threads, since this car is not highly modded that it is unlikely it is the exhaust manifold.
    I have a walker stainless gasket 31605 ready to replace the one at the rear manifold and downpipe, but know you got me wondering if that may not be where the leak is due to all the noise, fumes and heat (exhaust gas is getting inside car) I have Seafoam and I can get it put into the upper intake and check for smoke.
  2. #2 Re: Gasket replacement for Stock Manifold to 2.5" ZZP Downpipe
    Quote Originally Posted by NotEnoughGPs View Post
    the stock rear manny cracks stock, replacements also crack. or it could be the stock flex.
  1. Rear Exhaust manifold to downpipe gasket
    By bigdan002001 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2016, 09:22 AM
  2. close thread
    By DoubleBlown in forum Wanted To Buy - Parts
    Last Post: 07-09-2014, 03:38 PM
  3. will 3" downpipe fit on my stock manifold?
    By MOTELETJR in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-05-2010, 01:00 PM
  4. Manifold Gasket Replacement... Questions
    By brownb66 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 10:54 AM
